Which Jeans do you use?
   / Which Jeans do you use? #11
I really like the carhartt jeans. But since I work in a paper mill I usually get what's on sell at my local rural king. I would trash a pair of jeans at the mill in about a month from all the oil, dirt, white water and just plain wear and year. As for girl work jeans I can't help on that.
   / Which Jeans do you use? #12
Another vote for Carhartt's.
The main problem I have with them is they fail in the crotch stitching. It starts as a weak spot and then that one day you stretch and hear that ri i i i p! But they still hold up better than the other brands I've worn.
   / Which Jeans do you use? #14
Wrangler<---<<<:thumbsup:
An carhart shorts in summer.
I have one sute with matching shoos.worn 3 times.wedding,2 funerals
2 pair of rebocks, an one pair of slip on boots.
easy life here.
Army Grunt
Kate has 2 pullovers.
   / Which Jeans do you use? #15
Have worn jeans for most of my 62 years. My will directs that I go to my grave in well worn jeans & a T shirt. :thumbsup: As an adult I've preferred Wranglers as I could find 28" inseam, most others start at 30" inseam & I walk holes in the cuff. Don't like rolled up cuffs. Could occasionally find 28's at a nearby Walmart 1-2 pairs at a time so I looked often. A year ago I found a whole stack of 28" Member's Mark jeans at Sam's Club, got 8 pair. Took a little time to get used to the tapered leg but they're comfortable & holding up well. Will buy them again. MikeD74T
   / Which Jeans do you use? #17
Been wearing full cut Wranglers for 30 years, don't plan to stop.
   / Which Jeans do you use? #19
I had worn Lee and Levi's for years, but they developed the problem of wearing out the front pockets (keys in one and change in the other). I recently discovered Real Work Wear jeans at Rural King. Normal price is $10, but they can often be had on sale for buy two get one free, so they're only about $7. I've worn them for a couple of years and have found them to be more comfortable and durable than the Lees and Levi's that I wore, plus much cheaper. I also find them to be more durable than the Faded Glory and other private label jeans that I had tried from Wal mart.
Good luck and take care.
SCAN TO RECEIVE TEXT UPDATES (A51242)
SCAN TO RECEIVE...
2015 Chevrolet Impala Sedan (A49461)
2015 Chevrolet...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A51222)
2018 KENWORTH T680...
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A51039)
Kenco PH9000...
2019 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
