low temp electric space heater
   / low temp electric space heater #1
klink
Ohio
Ford 660,JD 4110 Hydro - JD 670 gear - 48 Farmall Cub - 51 Farmall H - John Deere 50 - JD X540 JD X580 AC 917 WH 81 Cub Cadet 1541 & 70
I'm trying to heat a porch enclosure and keep the temp down to 50 degrees. I purchased an Eden Pure electric heater, and it works great. But I can't get it to stay below 62 degrees, even at its lowest setting. Do any of you know of an electric heater that will maintain the temp down to 50 degrees? This is to save energy in an area not used much.
   / low temp electric space heater #2
you can put it on a timer and program it to go on and off a few times a day.
   / low temp electric space heater #3
I have a couple of heaters with digital thermostats. Anytime the units are turned off the setting has to be reset.
   / low temp electric space heater #4
Thermo cube plug in thermostat. Not adjustable but they have plugs with different ranges. I use a 35 to 45 degree in my chicken coop. Works good and not expensive. Less than $20. Check voltage ,amps etc. of course.
2015 FORD Transit VAN (A50323)
2015 FORD Transit...
8 Ft Fork Extensions (A50322)
8 Ft Fork...
Wolverine Mini Skid Grapple Bucket (A50514)
Wolverine Mini...
UNUSED JCT SKID STEER QUICK ATTACH 84" DOZER BLADE (A51244)
UNUSED JCT SKID...
2023 BANDIT SG-75 STUMP GRINDER (A51242)
2023 BANDIT SG-75...
2007 Polaris Ranger (A50514)
2007 Polaris...
