MF 130 lift arms not lifting a load
   / MF 130 lift arms not lifting a load #1
hinsonfamily
MF 130
I am new to the forum. I have been serching the net for help with my dad's MF 130 when my search brought me across this forum. The MF 130 hydraulics raise lift arms sometimes and sometimes nothing happens. Sometimes they will hold up and other times a load causes it to start dropping. Increasing rpms will help a little. It started while using a bush hog when the lift arms dropped the bush hog and have been undependable ever since. Any help would be greatly appreciated.
   / MF 130 lift arms not lifting a load #2
Either the control is stuck or the lift cylinder has a leak. If it has a side plate on it, you'llhave to open it up and check.
2025 TPM-16 Mini Hydraulic Excavator W/Dozer Blade (New/Unused) (A59225)
2025 TPM-16 Mini...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
Enerpac Hushh-Pup Hydraulic Power Unit, Model Per-132, Product Code B14880, 1/3 HP, 120 Volts, 1 (A59076)
Enerpac Hushh-Pup...
1983 KENWORTH W900 SLEEPER (A58018)
1983 KENWORTH W900...
PALLET OF MISC BOAT MOTOR PARTS (A58374)
PALLET OF MISC...
Kubota M135GX (A57148)
