New BX mower decks are much nicer!
   / New BX mower decks are much nicer! #1
RayBo
Member
While picking up a replacement tire for my BX24, was checking out the new machines and noticed the new mower decks have improved nicely.. this might not be new news but it was to me.. the belt appears to be well over an inch wide and the gearbox (cast iron) looks like it can take a beating. I have the 54" fine cut, and never the cast aluminum home depot tractor-ish gearbox, especially since it leaked since day one. Must say overall the newer machines appear to be much more sold than my 2006.. hope Kubota stays on that trajectory with these little machines.
   / New BX mower decks are much nicer! #2
My BX is from around 2005 or 6 and I think it has a cast iron gearbox. What's yours made of again? Aluminum? I have the 60 inch deck, but would've thought they'd be the same.
Hi Jesseb3, I think you have the standard deck - that had the cast iron box. I opted for the "fine cut deck", which I thought would be the same as gearbox at least (they didn't have one at the time I ordered the machine) and to my surprise it was aluminum. I think both the fine cut and standard decks have cast iron now. I don't have an issue with cast aluminum, done properly.. it's just that the gearbox I have doesn't look like it will hold up and it leaks!
   / New BX mower decks are much nicer! #4
I've had my 54" since 2004 and still have the original belt..The only thing I've replaced is the blades.
   / New BX mower decks are much nicer! #5
The 60" deck on my 2004 BX2230 has a double looking belt that is original and in great shape. Gearbox is extremely sturdy with no leaks also... I figured all were this way.
   / New BX mower decks are much nicer! #6
That is the way our 2003 BX2200 is, I actually prefer it to the one on our BX2660 as it has more steel, not plastic pulley covers.
   / New BX mower decks are much nicer! #7
Same here for my 04 BX 23. I do recall at the time of purchase, they suggested checking the grease on all spindles. (IMO, I believe many Kubota products where just starting to be made more cheaply right around this time, I know when the BX24 came out..I was glad i did not wait any longer to buy it!)
   / New BX mower decks are much nicer! #8
When I bought the BX 2660 my salesman told me to purchase the standard deck. He claimed the fine cut was designed for southern turf varieties such as St. Augustine.
   / New BX mower decks are much nicer! #9
There were several posts from the early 50 series BX MMM's (the MMMs' were also redesigned from the earlier 00 & 30 series) that the spindle nuts/bolts were either not torqued correctly at the factory or not installed correctly and that they would work loose causing the entire spindle assembly to wobble during operation. Some wallowed out the mounting holes while others would cause the belts to jump off the spindles. when caught in time there was no damage and new lock nuts fixed them right up. Kubota eventually found and fixed the cause and it doesn't seem to be a problem anymore.
My 04 BX23's 60" MMM hasn't let me down yet and it is my primary finish mower. Everything on it is still OEM factory (double belt, pulleys, bearings etc) and they look to last for quite awhile longer.
I stow my MMM up vertically on axle stands during the offseaon and I noticed the PTO shaft seal on the gear box started leaking last winter when stowed. I changed the gearbox fluid (SUDT factory fill) to 80w90 this spring when I put it back into service and it never leaked during operation and thus far hasn't leaked since I've stowed it this winter. Should it leak I'll go on ahead and replace that seal before spring. If it doesn't leak I'll not fix it :D Other than that it's been a good hard working implement thats only requred greaseing :D
Dave
   / New BX mower decks are much nicer! #10
The AL gearboxes push oil out the breather really easily, that maybe what your seeing. We get alot of people who ask about it. It does not seem to case a problem, other than making a mess.
UNUSED FUTURE GD47 47" LAND LEVELER (A51248)
UNUSED FUTURE GD47...
2022 CATERPILLAR 279D3 SKID STEER (A51246)
2022 CATERPILLAR...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2009 Jordair Marines-320-DH Trailer Mounted Air Compressor (A51691)
2009 Jordair...
(APPROX 250) UNUSED LANDHERO 30" TRAFFIC CONES (A51248)
(APPROX 250)...
