Antifreeze
   / Antifreeze #1
MIKE R
Elite Member
CANADA
Many
I looked in the rad today on my Case Sc. The antifreeze I put in the other day was going slushy. It is mixed at 60 Antifreeze/40 Water. It was only -5 degrees Celsius out today. When I put the antifreeze in I checked it with the antifreeze tester it read that the freezing point was about -40 degrees. I've never seen antifreeze do this.
   / Antifreeze #2
can always richen it up a bit...
   / Antifreeze
I was thinking about the antifreeze. Since I put the new antifreeze in I haven't run the tractor or turned it over. May be the Antifreeze/water isn't mixed together. This would explain why the top layer is slushy. Water was the last thing I put in it. I'll have to start it or turn it over a few times to mix it up.
   / Antifreeze #5
Since you didn't pre mix it before putting it in you need to run it to operating temperature for a while to mix it up.
You need to get the temperature up to open the thermostat to get the antifreeze/water to circulate and mix through the system.
   / Antifreeze #6
Make sure that you used full strength antifreeze and not the 50/50 premix that comes in the same color jugs. Friend of my brother found this out the hard way a couple of winters ago!
60/40 mix but using 50/50 mix you end up with ~30/70 (antifreeze/water)
Like others have said you probably need to mix it up a bit.
AND then use a tester to verify that it has the correct protection.
   / Antifreeze #7
Full strength antifreeze freezes at about 12F where as 70/30 mix antifreeze/water is good to -51F. Mix higher ration of antifreeze and the freeze point starts to rise. 60/40 mix that you have is supposed to be good to -45F. You DO need to run you machine for several minutes after the thermostat opens to make sure it is well mixed.
   / Antifreeze #8
as only as he is at least 10%water.. the af freeze temp is quite high.
70% is ideal, but 90% protects the same as 45% :)
80% is the big bench mark where you are still at -50 and then when you go a lil higher you loose 30 degrees protection. mine are in degrees F
   / Antifreeze #9
I know you are saying degrees 'F' but the numbers you are using are in degrees 'C' :)
70% is good to -51C or -60 F :)
   / Antifreeze #10
Hats off to you, as you are not not being Metric impaired :) :). Tons of Canuck Snowbirds land in your area every fall Chris?? :)
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
CATERPILLAR HANG ON 71" WHEEL LOADER FORKS (A51406)
CATERPILLAR HANG...
2016 Case 821F Articulated Wheel Loader (A54811)
2016 Case 821F...
BENNU HYD SCAFFOLDING SYSTEM (A52706)
BENNU HYD...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
