John Deere 110 vs Kubota M59
   / John Deere 110 vs Kubota M59
dsgsr said:
In My state you don't have too take a class. I went to my local DMV, (Department of Motor Vehicle) got the CDL study manual. Read it at least 3-times (I don't remember well) Sent in for the written test, got my permit. Read the manual some more, sent in for my Road test. got my Brother (who is a CDL-A) too go with me, this is a must. Took the road test with my 550 and 6-ton trailer (trailer, which by the way is for sale), passed. Now I have a CDL-A. The one thing I did also was too set up the trailer backing test (it shows you in the manual how to) and practice a few times.
David
If that's all that's too it I would think of doing that. I was just assuming there was a class and such to it. If its just a test and a drive then I see that as a possibility
MessickFarmEqu said:
For your fact finding, we just traded an L45 with 75 hours on it. Priced at 32k. Was a hobby user, moved up to an M59.
That's probably a little out of my budget for now but it does have about 1600 hours less than what I'm looking at now! Does it have all the hydro options?
   / John Deere 110 vs Kubota M59 #72
I'd be very surprised if my 110 is not just over 8,000lbs. With the HD 20" hoe bucket, the QA attachment, the hyd thumb, the belly pan, the stabilizer shields.
My first trailer was a 22' - 14K tilt-bed. Really liked everything about the trailer - except the fenders! Loading and unloading plywood, dimension lumber, etc. on/off that trailer was more than I could tolerate!!
Went to a 23' - 15.7K gooseneck deck-over trailer. Now, I can use those forks the way they're supposed to be used... :thumbsup:
I agree with MartianTractorMan's view of "going bigger". Better to have more trailer than be right at the limit.
Besides, if you upgrade to the M59 - you'll be alright there, too.
Just have to take a written exam and driver's test up here for a CDL. (I've got the book.. just have to work up the gumption!) Something I've been kicking around for several year's now. With a bigger tractor and bigger equipment (MoCo) it's about time.
AKfish
AKfish
I would go with a gooseneck but don't always have a pickup. My pickup (F250) shares its life between me and my parents. Although were only miles down the road from each other it sure is nice not to have that reliance. My 4500 isn't able to haul a gooseneck because the 4x4 option adds about 6" onto the 2x4 platform and I got larger tires which brings it up even higher so a gooseneck wouldn't fit. I have a 10" chrome drop hitch that was about $250 for that thing just to pull it - it's almost to tall! But I don't like the reliance and would rather just have a trailer. I have been looking at some tag trailers though. They do have the flat deck and I see used ones on CL for pretty cheap. Still not sure on the trailer situation.
I had to work later again tonight but I will call tomorrow for sure. I have been still looking around so I don't get to focused in on just this one and find a better deal and I found this one. It is more money but it is new and has 1000 less hours. It doesn't mention if it has the 3 rear remotes but I would doubt it. I was wondering how much that the three remotes would be, and they probably couldn't be the "factory" remotes could they? Also how much is a thumb as it doesn't have one? Think I still like the other, just trying to keep my options open.
2006 DEERE 110 Machines - Loader Backhoes For Sale At MachineryTrader.com
David
Thanks for the info David. I would be considering your trailer if and when I end up getting a 110. Wouldn't want to jump the gun though:thumbsup:
   / John Deere 110 vs Kubota M59 #75
   / John Deere 110 vs Kubota M59 #76
Tractor looks to be a pretty straight machine. The 4n1 looks well used... but not abused. Pretty sure that the hoe has the 7th function - appears that the coupler ends are near the top of the dipper arm.
Hard to say about the rear SCV's - whether the machine has them or not. They are OEM and not available as parts; per se. The "end around" for them could be achieved with an add on 3-spool hyd valve body and quick disconnects. You would plumb the 3-spool valve into the backhoe, Power-Beyond Circuit. You could easily find ways to spend another $7-800 for parts on that project - never mind your time!
The list cost for the thumb was close to $2,500. One caveat, however. I couldn't tell if the hoe has a Q/A bucket. Gotta have the Q/A with the thumb install. Pin-on bucket = no thumb. I don't remember what the Q/A hoe bucket was - but - of course, it was "optional".
No mention in the listing about the 3pt hardware, either. Regular hardware from a 4000 series machine is gonna be in the neighborhood of $1,500 or so.
When you start factoring in these additional costs - it makes finding a machine with those options "installed" a much, much better buy!
AKfish
AKfish
Yea, wow. Didn't even think of some of those things. By the sounds of it I'd be paying close to $7k more with all the stuff to be added. I don't like the sounds of that.
I'll be sure to update after I call the dealer
   / John Deere 110 vs Kubota M59 #78
Quote "My 4500 isn't able to haul a gooseneck because the 4x4 option adds about 6" onto the 2x4 platform and I got larger tires which brings it up even higher so a gooseneck wouldn't fit. I have a 10" chrome drop hitch that was about $250 for that thing just to pull it - it's almost to tall!"
I have a 20+5 Gatormade 22.5k gooseneck trailer, and I can tell you that the gooseneck itself is adjustable up and down for height. I see semis pulling goosenecks all the time. I realize you have an ultra custom truck, but I would check on a gooseneck all the same.
   / John Deere 110 vs Kubota M59 #79
Trailers can get expensive fast and when you are on a budget it depends alot on what you can find used or new that is good enough to haul your tractor safely. when buying my 110 I bought a Bix Tex 12PI 12k, 20ft with spare and slide in ramps about $3000 new. Will have had this for 7 years in Febuary and no complaints.
Lots of people make this style trailer and while it is irritating to move some materials it is easier with others so there is some give and take. I like the fact that the deck is low which keeps the cog lower too. Tires are outside the floor and spaced full width.
Here is a link to the 14PI which is only 2990 lbs and is the one I would buy if I had it to do all over again. This allows for an 11,000 lb payload in as light a trailer as you will find. Look at bigtextrailers.com http://bigtextrailers.com/pdf/14pi.pdf
Alright, just got off the phone with the dealer. Said everything was in good working condition and ready to go, only problem is he wouldn't take a trade in on mine because of the distance. That is another PITA to have to sell it, much easier to trade it in. Didn't want to have to deal with shipping there and back. We'll have to see where this goes because any of the others are even further and if they won't trade in anyway then I'll be in the same situation. Ever heard of this?
Deere 310L (A53317)
Deere 310L (A53317)
UNUSED FUTURE ZWB 59"HYD MINI STRAIGHT DIGGING ARM (A58376)
UNUSED FUTURE ZWB...
2015 Chrysler 200 Sedan (A56859)
2015 Chrysler 200...
UNUSED FUTURE SE61 61" HYD SWEEPER (A58376)
UNUSED FUTURE SE61...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
265 Gallon Tote Tank (A59225)
265 Gallon Tote...
