HST 2615 Glow Plug light stays on
   / HST 2615 Glow Plug light stays on #1
optimist
Sometimes it goes out 'normally', but then it may come back on constant or flash like it's got a short. I'm guessing the relay (but that's just a guess). I don't know where it is though...any other things I should check or a pointer to where the relay is would be great.
Thanks
Joel
   / HST 2615 Glow Plug light stays on #2
Thanks
Joel
The timer/relay is located under the black cover below the steering wheel, on the left side.
Ah, so the timer and relay is in one piece. That the thing labeled "NGK OGS Controller", model # S85NE? Are those still available or is this where the conversion kit is needed?
   / HST 2615 Glow Plug light stays on #4
Those are now obsolete. I just changed mine today to the new 10 second timer with different glow plugs than work with the 3 second timer. It was a very easy fix, just expensive, $200.00
Be sure to blow all of the crud away from plugs before removing. One member with another brand tractor had a temporary problem when a piece of debris got into the glow plug hole.
   / HST 2615 Glow Plug light stays on #5
Witch one replaced the S85NE
Thanks
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
2008 MAGNUM LIGHT PLANT (A50854)
2008 MAGNUM LIGHT...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
2013 PETERBILT 367 (A50854)
2013 PETERBILT 367...
