power beyound line on 305 JD fel
   / power beyound line on 305 JD fel #1
rcausey
john deere 3038e
I am putting a WR long 3rd function valve on my 3038e JD with a 305 fel. Can anyone tell me which line going to the 305 loader valve is the PB line?
   / power beyound line on 305 JD fel #2
Do you mean the PB out port on the FEL valve. If so, there is normally a stamped or raised lettering by each port, PB, PBY, etc
Does your loader valve have 6 or 7 hoses connected now.
Your valve flow is 5.3 GPM, and 2500 psi.
It has 7 lines. I looked on the valve body,but could not see any markings.
   / power beyound line on 305 JD fel #4
The PB line will be going to the side or back of the tractor.
Trace the hoses for the OUT port and the PB port off of the FEL.
Can you take a close up pic of the FEL valve, showing both the input and the output sides.
The input line from the pump goes to the P port, and the relief valve will be close to that port.
The other side/end section will have the PB and the OUT port.
Thanks for the info JJ the only port marked has a p. It is a metal line on the right side of the valve. There is a metal line on the left side of the valve. Both of these lines go to right rear of the tractor in what I assume is the pump. The third metal line comes out of the left side of the valve in front of the other two lines. This line goes to middle right side of the tractor. All of the other lines go to cylinders on the fel. I don't know how to post photos or I would send you one. THANKS
   / power beyound line on 305 JD fel #6
Ask most any young person and they can show you how to post. I have been where you are on picture posting. Go ahead and take the pictures wit a digital camera. You can buy them cheap. That is the first step.
Thanks for all the info. I talked to Nelson at WR Long today. He said the PB line was the center line on my valve. I hooked it up that way and it worked just the way it was supposed to. He said he had problems locating the PB line on 305 loaders before. There just doesn't seem to be any literature on the system.
2014 Kenworth T370 Single Axle Dump Truck, VIN # 2NKHHM7X6EM419999 (A57453)
2014 Kenworth T370...
2020 Ford F-150XL (A57148)
2020 Ford F-150XL...
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2017 JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
2017 JOHN DEERE...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
