Another way to "quick & easy" hitch
   / Another way to "quick & easy" hitch #1
pat32rf
Bancroft, Ontario
JD4300
A few days back I was visitin' with an old guy out in his barn. He went on about always loosing money, poor crops, bad weather, crummy govment, etc. Nothing new.
I then noticed a piece of chain hanging from a beam in an open area of his barn. When he saw me looking he explained that no, he wasn't about to "stretch his neck", but that was how he changes his implements all by himself.
Each of his implements has a lifting ring, or chunk of chain fastened to the top, at about the center of balance. He backs up under the chain with the 3pth raised and hooks onto the chain and lowers the 3pth until the chain takes the weight. He then uncouples and picks up a skid with his FEL forks. He lifts the skid under the implement until the chain unhooks and then he sets the skid out of the way while he picks up his next implement (on a skid) and hangs it from the chain. With the implement hanging and free to move, its a simple job for him to line up the 3pth and make the connections.
He showed me how easy it was for him to remove his back blade and install the snowblower, using only a small carpenters hammer to tap the arms and PTO shaft on or off....
Even if the lifting point is not exactly right, its a simple matter to tilt the free swinging implement by hand. On some (cultivator) he doesn't bother with a skid. On others he has fastened blocks to the skid (back blade) to balance the load in place.
He tells me that the hardest part was finding the center of gravity with the chain in the barn, then taking every thing down to the welder in his shop to weld on a ring, or short piece of chain. When I asked why he didn't just hoist with his FEL (at the shop) to find the CofG, I got a real funny look.......
   / Another way to "quick & easy" hitch #2
Hanging the iimplement would make it easier to hookup than leaving on the ground. Problem with it is its not quick, Most farmers seem to be welders in self defense. You either need to be able to do it yourself or have a large enough operation to have someone working for you to fulfill this job.
IMatch with properly setup implements is alot faster, easier and safer to use.
   / Another way to "quick & easy" hitch #3
I have a ( A frame ) that has a set of wheels. I roll the A frame forward and very similiar to your description I disconnect and lift the implement with a 1/2 T chain block and roll the hoist back to where the implement was removed from. I then choose a different implement and lift and bring it forward and connect on.
I move the order around slightly for the seasons , in July the snowblower is at the back of the lineup, by October the flail mower and the snowblower have changed places.
With this method I have the toys packed in very tight, so floor space is not wasted.
This is the bases of a automated warehouse with pick and reach stacking.
When I was an apprentice I worked for several months at an IBM automated warehouse that was designed for this concept. I spend hours installing duct o wire power rails.
When they started up the monorail stacker and it started to travel faster it blew open the duct o wire bars ( not my fault ).
Seeing I was so good at hanging 80' in the air on a 2x10" plank ( tied off ) I got to put a retainer clip on every joiner section.
Craig Clayton
IMatch with properly setup implements is alot faster, easier and safer to use.[/QUOTE]
Didn't seem to take him very long, compared to my backing and filling, the prying and hammering....., then carrying implement to storage spot. (I'll probably move it twice more before I use it again)
An IMatch set-up would be as much as I have in my most expensive implement (snow blower), plus a some of the others are hand-made with non-standard pin spacings/configurations.
   / Another way to "quick & easy" hitch #5
Craig Clayton
Would really like to see some pics of your setup. I am researching the same exact method using a HF rolling A frame hoist. Thanks
   / Another way to "quick & easy" hitch #6
Rolling around A frames, must have concete floors. Have done similar just hanging equipment off tree limbs myself. Just saying..
2025 Swict 72in Bucket Skid Steer Attachment (A53421)
2025 Swict 72in...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
