Help ID old Dearborn plow
   / Help ID old Dearborn plow #2
Obviously the plow is a Dearborn 10-1...plenty out there..I've got a completely redone 10-8. If the shears/points are good, keep it...if they are worn out..good luck finding any more for almost any price. As far as the disk, grease it up and pull it.. good luck. BobG in VA
Any idea as to date of manufacture?
   / Help ID old Dearborn plow #5
I have a Dearborn plow I need shares for it, I searched everywhere for them and couldn't find them.
So I decided I would make a set for my self, I have drawn up a set in my CAD software of what I think new shares would be like (I dont have a picture of them new I am working on what I have left and a lot of guessing).
Does anyone know where I could get a picture of what the shares looked like originally? Measurements?
And do you think there would be any market for making the shares for others?
Did you see this?
1951 Dearborn Plows - Ad Brochure
   / Help ID old Dearborn plow #7
thank you Ridgewalker,
does anyone know what is the logic on shares that curve down to a point vs flat like a razor?
   / Help ID old Dearborn plow #8
I think your asking about the "scotch bottom" plow. IIRC these are used to turn the sod over better on wet ground. I can remember seeing a few of these as a kid but have never seen one used. Probably real good in wet, boggy conditons. I believe that the sod remains partially attached to the ground via its roots which rolls the sod better. Thus turned the ground dries out and kills the exposed roots....and the operator would later follow with a disc or other implement.
Great to see that old sales literature Ridgewalker! Nice read compared to today's literature....where you may only get 1 picture.
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB 1.5 Ton Crane Mechanics Truck (A52377)
2015 Ford F-350...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2012 LEEBOY 8515B ASPHALT PAVER (A51406)
2012 LEEBOY 8515B...
