Need a Ford
   / Need a Ford #1
murphy1244
Super Star Member
Ohio
Kubota 1120 RTV Kioti DK-40, MF-135, Ventrac 4500Y
Looking for a ford 9n or 8n To run a 6 foot rotary cutter. Ohio area. Someting nice. Pm Me.....
   / Need a Ford #2
sorry.. your message doesn't make sense :)
a ford 9n, 2n, or 8n simply doesn't have sufficient pto hp to adequately run a 6' rough cut rotary cutter.. or lift it for that matter.
a 6' finish mower would be acceptable.
I reccomend you look into the 53-64 years if you NEED a 6' mower.
while a naa, or 6xx / 7xx / 2000 4 cyl WILL run a 6' mower.. I'd suggest a 8xx, 9xx / 4000 4 cyl. If diesel, it will be a 59 or newer, and if going diesel, I'd stick with the 8xx/9xx/4000 as it will have the easier to get part$ for 172ci engine.
given a choice of any of those model for mowing.. i'd go for a 4000 rowcrop with wide OR narrow front end. if you need to maneuver.. go narrow.. if maneuvering is not a big deal.. go wide.
the rowcrop gets you up higher to see better. I'd also reccomed a 5 speed model ( denoted by a *5* or *6* on the 55-62 models.. preferably the *6* dual clutch if possible.. and power steering. If you find a 4 cyl 000 model and it is 5spd with original trans.. it will be a dual clutch.
any of those of those should be able to be found in the 3000$ or less range, depending on local market...
if you have any questions, just post em.... i got a barn full of fords...
soundguy
   / Need a Ford
Thanks Sound guy, So I guess scratch that. Was looking fer sumting old to mow with so I could just leave the rotary on it. Thanks for setting me straight.:)
   / Need a Ford #4
8n made it to 52.
bump to 53 and that gets you a NAA and WOULD work.
bump to late 54 and that gets you a 6-7-8-900 series.. and they FOR SURE will work.
what's 2 years?
soundguy
   / Need a Ford
So in your opinion I should be looking for???? Thanks:)
   / Need a Ford #6
from my first post:
soundguy
   / Need a Ford #7
in the prev post, the first 2 are my 63 4000 rowcrop with factory wide front with a 4 spd and combo sherman hi low tranny.. making it 12 forward gears and 3 reverse..
the last one is my 950 'essentially' the same chassie of the other rowcrop save the front pedistal..e tc. showing you a narrow front option. VERY NIMBLE.. that one has the 5spd tranny... same essential machine as a 7xx or 2000 rowcrop 4 cyl... except for the smaller 134ci engine..e tc..
these next pics show my 63 2000.. same essential chassie of a 6xx and similar to an 8xx, but without the hp. just showing you the difference in height. which may help you decide between an ag and a rowcrop for mowing..e tc..
soundguy
   / Need a Ford #8
i would find a 4000 with 5 speed or maybe a little newer 2000/3000 with 8 speed
   / Need a Ford #9
i was going to suggest a 3 cyl as well.. but it appears he want's to stay as 'old' as possible.
though for sure that 8spd would be nicer for gear options..
soundguy
   / Need a Ford #10
What would be wrong with the 8n/9n and stepping down to a 5' cutter??
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A55302)
2020 New Holland...
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
