Ford 101 Bottom Plow
   / Ford 101 Bottom Plow #1
Tucker dog
Allis Chalmers D 310
I have a Ford 101 bottom plow and the front plow has been rotated around. I have moved it back in place but cant get it to lock in place. I havent been able to find a manual for this either. Does anyone know how to fix this?
   / Ford 101 Bottom Plow #2
It probably has a shear pin that has sheared. The remnants of the old broken pin sometimes remains and has to be tapped out with a punch. If yours is a shear pin model (versus a spring latch type) it will have a hole in the housing that the pin slides into. I use grade 8 bolts (I think 5/16") for shears. Simply slide a new one in after rotating the bottom back into place where the holes line up. If yours is a spring latch model, the latching mechanism will need to be openned up and inspected.
   / Ford 101 Bottom Plow #3
Try this:
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
Utility Trailer (A52377)
Utility Trailer...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
