straddling a ditch with backhoe
   / straddling a ditch with backhoe #11
I suspect the cases where the backhoe can not lift the rear end fully are when the rear tires are loaded. I think my 110tlb would have a hard time straddling a ditch if I had an additional 1000 lbs of rimguard for instance.
Most of the snall tractors with add on backhoe's also have filled tires and all combined it is too much weight for these small hoe's.
   / straddling a ditch with backhoe #12
has to be said
maybe theres just too much dirt on the hoe...... its too heavy
no one likes a dirty hoe.
   / straddling a ditch with backhoe #13
I have a b26 with foam in tires and have been over many trenches with hoe lifting and moving carefully sliding around on front bucket. With the limited reach on this little hoe it takes some practice to finish up the end the trencher can't reach.
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A60460)
2017 Ford F-550...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2019 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60460)
2019 Ford F-550...
TEST YOUR BID BUTTON! (A60429)
TEST YOUR BID...
Aerway Tillage Tool (A59814)
Aerway Tillage...
