What did I just Buy
/ What did I just Buy #1
kansaskioti
Wichita Kansas
Kioti LB2204, Ford 1210
I just purchase a Kioti tractor with a KL120 loader. The tractor runs great it has a 2 speed pto, gear transmission with low and high ranges, 4wd. It has a foot throttle and a 5 foot bush hog my question is what model is it the serial number is 200348. The man I bought it from thought it was a 26hp but didn't know for sure I can't find any other markings, it stand a little taller then my Ford 1210 (approx 6 inches) rear tires are 54" wide. Can anybody help me identify this tractor:confused:
/ What did I just Buy #2
Can you post a picture?
I was thinking an LB or LK series or something along those lines but I'm pretty sure the KL120 loader is only on the CK-series tractors. Which would mean it's somewhere between a CK20 (20-22hp) and a CK25/27 (25-27hp).
/ What did I just Buy #6
He probably means a 2 speed PTO as in 540 rpm and 1000 rpm.
Thats what I thought but I did not know they would have that on such a small tractor. :confused:
Boone
/ What did I just Buy #7
Probably a 540 rear and a 2000 mid.. Also, probably a CK20, only thing that takes a KL120 ldr. I believe.
OK got a little more info out of tractor data .com I now am pretty sure its a LB2204 Due to the exhaust going out the top and the manual steering thanks for the help still not 100% sure of this but the picture of it on tractor data .com is pretty close the CK series has too much of a rounded nose my tractor is boxy
/ What did I just Buy #10
It probably has a KL122 loader.
They are a close cousin to the LK2554, last LB2204 was built in 1993.
They pretty strong for their 22 hp.
They would outwork an CK20 with 22hp, but aren't near as operator friendly.
BTI
Thanks for the input everybody I just got done talking to the local kioti dealer and it is a LB2204 built in 1988 and it is a KL120 front end loader but can't figure out what year it was built. Weather got better so I got to get and play on the tractor for a while. Here is a short breafing of what I learned. The hydrualics are not strong enough to lift the tires off the ground. Without power steering the tractor is a little tough to turn unless the bush hog is on the back then it's much easier. Going to look at modifing or investing in a power steering system.
/ What did I just Buy #12
I would like to see how someone managed to put a KL120 loader on a LB2204. LOL
I'm betting it's probably a KL120 sticker. Unless it's 1/2 of a KL128 sticker.
The KL122 and 128 are very similar loaders.
BTI
/ What did I just Buy #14
There should be a data plate riveted or glued somewhere on the tractor that would tell you.
2005 JOHN DEERE 310SG BACKHOE (A60429)
2005 JOHN DEERE...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
Bobcat S740 (A57148)
Hot Pressure Washer Trailer (A59228)
Hot Pressure...
2016 KUBOTA SVL75-2 SKID STEER (A60429)
2016 KUBOTA...
2014 Chevrolet Impala Sedan (A59231)
2014 Chevrolet...
