Camp fire: Suggest chunk of steel to stabilize heat output?
   / Camp fire: Suggest chunk of steel to stabilize heat output? #1
beppington
Elite Member
of my
Here
My friends & I like to sit around campfires/ bonfires at my place for hours on end, & these fires sometimes take a lot of attention in order to try to maintain an even heat output, so you don't have to move closer & closer to the fire, & then back away from it when somebody puts more wood on it or pokes at it.
I wonder if putting a big, thick chunk of steel in the fire would help stabilize the heat output, since it would also get hot & radiate heat more consistently than wood alone.
What do you think? Will it work? Anything wrong with this idea? Is it safe?
Any ideas on what large chunk of metal to use, where to get it, etc.?
I thought of maybe visiting a shop that repairs big rigs, & asking if they have an old, un-usable axle/ hub unit, so I could stand it up like a pole that would radiate. Or maybe an old set of dumbbells.
What got me thinking about this is a campground we stayed at that had an old big rig rim (or maybe a tractor rim; can't recall) laid out at each site for your fire pit, & the campfires we had in those seemed very uniform, like the rim was radiating and/or the rim helped the wood burn more consistently.
   / Camp fire: Suggest chunk of steel to stabilize heat output? #2
Steel will heat/cool very quickly. I think you want something that is slower, like fire brick. It will do better holding and evening out the heat. There is also a pizza oven brick that would be even better -- that's the whole purpose of it.
Ah, OK, good to know ... What about just cheap old 8x8x16 cinder blocks from Home Depot?
   / Camp fire: Suggest chunk of steel to stabilize heat output? #4
I wonder why our ancestorts used to surround the fire with stones?
Could be to contain it but may have been something to do with retaining heat as well.:)
   / Camp fire: Suggest chunk of steel to stabilize heat output? #5
Be aware of exploding rocks and blocks.:thumbsup:
   / Camp fire: Suggest chunk of steel to stabilize heat output? #6
Yes and wear goggles and a helmet oooh and gloves..forgot about the heath and safety:D
Yeah, I've seen what happens when you have rocks a fire, especially flint ... It shatters / explodes! ... and shoots out like bullets! Hot, sharp, firey bullets!
   / Camp fire: Suggest chunk of steel to stabilize heat output? #8
The best way is to use a small amount of wood that burns slowly. Hardwoods are the best for longer heat with a little wood. Rocks and fire rings will radiate heat but you will still have to feed the fire.
The fire rings are to contain the fire to a particular area. Some people have no fire savvy. They will a build a fire anywhere without thought of danger or the mess fire leaves. Every year thousands of acres are burned because of no fire smarts.
I was raised with wood heat and have done lots of land clearing and wildfire fighting. It's amazing what people don't know about fire safety.
   / Camp fire: Suggest chunk of steel to stabilize heat output? #9
Sorry...I just assumed that people would know what rocks to put around a fire and what to avoid.
Been messing with fire too long I spose:D
   / Camp fire: Suggest chunk of steel to stabilize heat output? #10
If you put a flat radiator behind the fire, it will broadcast the heat a lot further, but you will lose sitting area.
2015 DRAGON 130 BBL VACUUM TRAILER (A55745)
2015 DRAGON 130...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A53422)
2014 Ford F-150...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
UNUSED Under Mount Stainless Steel Sink & Faucet (A53117)
UNUSED Under Mount...
2017 DRAGON 150 BARREL TRAILER (A55745)
2017 DRAGON 150...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
