Ice Storm 2012
   / Ice Storm 2012
During the October storm in New England our power was out for 7 days. I ran my small B7100 at high PTO rpm and slowed the engine down to power my 7kw generator. Voltage was checked often but did not waver once the RPM was set. I only used about 1 to 1 1/2 gallon for 6 hours. The tractor ran our heat and a few lights about 16 hours a day. Just surprised you burned so much fuel.
My L4240 is 44hp,it does not have a two speed pto;engine rpms were about 2300.I didn't feel it was too bad on fuel,I keep pretty good tabs on use all the time.Running my tiller,I use about 1.25 gal.per hour.$4.00/hr in fuel use is worth it to me to run my whole house/garage and not freezing up.
In the spring when I am hatching/brooding pheasant;I can't be with out power at all.
My son useing a gas 3000 k generator used more fuel than I did just to run his heat,a few lites and the fridge.
   / Ice Storm 2012 #12
Looking at this thread looks like we dodged the bullet....during these figid temps today, i'll have to crank up the gen for good luck today....:thumbsup:
   / Ice Storm 2012 #13
One gallon per hour is reasonable for 10K of power. Glad you had enough fuel on hand.
Last outage we had I used a 6K gas generator and it used at least 1gal/hr, maybe more.
I plan to install a standby unit propane powered.
   / Ice Storm 2012 #14
I was lucky on 98. We never lost power while most around us did. It's funny how quickly those elected to lead forget the lessons of the past as our gov wants to shut down our nuclear power plant and rely on getting power from Hydro Quebec. The same lines that were toppled by the ice.
We got a few inches of snow this weekend but nothing out of the normal. Only lost sat tv because the snow started off real wet then froze to the dish. I've got a 4200w Honda that I've toyed with replacing. But I keep leaning towards a Kubota stand alone 10k vs a pto gen.
The stand alone Kubota burns about .4 gal/hour on half load. nybirdman, any idea how much power you were using when you were burning 1 gal/hour? Any guesses how many hours you put on your tractor over the last few days operating the pto generator?
   / Ice Storm 2012 #15
Some how we lucked out and kept power. With all the rain and quick temperature change things could have been a lot worse. Every school in the area closed because of the ice.
   / Ice Storm 2012
Crazy:thumbsup:Al
Just checked...I put about 14 hrs. on the tractor to power the gen-set.
Peak use I was at 7k..that was on start up.With this gen(and I assume all) you have to keep a minimum speed to maintain correct voltage;so you can't throttle back or you would have low voltage.I am not an electrician,my brother in law(who is and electrician) was here when we started.He had installed my switch...like I said everything worked perfect.
I know there is a lot of debate here between Pto and stand alone gen-sets,I made my choice and happy with it.
   / Ice Storm 2012 #17
Crazy Al
Yes, it's all about choice. I made mine, too, 20 kW standalone, auto transfer switch, propane powered. No worrying about fuel storage, propane can sit for quite a while. Our unit exercises weekly to ensure when needed, it will perform. I only have one tractor, it's not tied up on the genset when needed for other tasks. If my wife and daughter are home alone during a power failure, they just wait the minute or so for the system to come up, then all is as before. With a "full" tank of propane, about 9 days continuous running at half load. After the grid is back up, it's a seamless transfer. The maintenance is horrible, :D oil change every year, or 200 hours whichever comes first. It is funny how a lot of folks that have endured a BAD ice storm, only do it once without a generator of some kind. We were without power for 9 days during a "catastrophic and historic" ice storm in January of 2007. My wife tells me all the time how happy she is we have it, and the peace of mind it gives her, knowing we'll have power when we need it. Mark
   / Ice Storm 2012 #18
If I didn't have a small gas generator that is enough to get by with I would have done something before now. I keep going back and forth between a stand alone and pto. I'm trying to figure out how many hours I put on a generator a year and if I would need the tractor for anything else during that time.
   / Ice Storm 2012 #19
Al,
I have a larger stand alone diesel genset from Central Maine Diesel. They supplied a nice unit, customized to my needs with a sound enclosure and belly tank. I am addicted to Orange and so I bought Kubota. We have many outages in my neck o' the woods, some for 5 or more days, and often with several feet of snow needing plowing, so I went with standalone.
Here is a Kubota unit that you might be interested in: http://www.generatorsales.com/order/Kubota-12000-Watt-Diesel-Generator.asp?page=KB1200
   / Ice Storm 2012 #20
Al,
A also bought my standby/back-up power system (propane) from Central Maine Diesel (a Winco unit)....about 13 years ago...since then they changed their name to CMD powersystems Generator sales and service. For all your emergency power needs call CMD Powersystems, Inc. [ Home Page ] Great people to deal with...of course in my case they are only about 30 minutes drive from here
TAKEUCHI TB250-2 EXCAVATOR (A52705)
TAKEUCHI TB250-2...
TORO TRX-20 WALK BEHIND TRENCHER (A51406)
TORO TRX-20 WALK...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
2016 HINO 195 16FT BOX TRUCK (A54607)
2016 HINO 195 16FT...
