4600 blowing hydraulic filter
   / 4600 blowing hydraulic filter #1
junkyard
99 johne deere 4600
i have a johne deere 4600, it blew the oring and cracked the filter. i replaced and did the same thing. I assume it has a bypass stuck. I am not sure where to look. any and all suggestions would be a great help. I need this to make money so time is of the essence. Thanks in advance
   / 4600 blowing hydraulic filter #2
Most filters have the by-pass built into the filter housing.
i read on a previous thread about stuck bypass, any other suggestions ? and ty
   / 4600 blowing hydraulic filter #4
My guess is your hydraulic relief valve is set too high or you have an incorrect filter.
johne deere filter, i am trying ot find out where the pressure relief valve is , any suggestions?
   / 4600 blowing hydraulic filter #6
john deere has very good parts illustration available on-line. You should be able to do a little research and find all the info you need.
i have never reset the valve either, it has 1k hours on it, was working great then blam
trying to find the parts illustration , went to their site and checked parts . I am not seeing it , and ty
found it thanks. I assume a stuck valve would cause my problem?
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52128)
2018 John Deere...
Quick Attach Pallet Forks (A47384)
Quick Attach...
1270 (A50490)
1270 (A50490)
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50774)
UPDATED INTERNET...
2012 International 4300 Reefer Truck (A52128)
2012 International...
