Vicon RV 1601 or Vermeer Rebel 5500
   / Vicon RV 1601 or Vermeer Rebel 5500 #1
rwk5412
Member
2003 New Holland 5610s
I can pick up a 2008 Vicon RV 1601 for about $9500 or a 2004 Vermeer Rebel 5500 for about $9,900.
I have been doing my best to research the two to determine which would be the best, but I am not sure.
We bale about 700-800 bales a year of coastal hay with an 80HP tractor. Looking for reliability, low cost of maintenance, etc.
I know Vicon sold off the baler division to Kuhn, which makes me question the ability to get parts after the 10 years or so are up. I know Vermeer isn't going anywhere, but is the 04 Vermeer worth the same as a 08 Vicon?
Any insight on this matter is greatly appreciated....
   / Vicon RV 1601 or Vermeer Rebel 5500 #2
vicons used tobe real good round balers.we bought an ran a RP 1582 variant baler back in 91 an ran it for 9yrs.an it put up real tight bales when set right.if i was you id ask the dealer alot of qs about both of the balers.i do know the vermeer 5500 is good balers to bale 300 or 400 bales a year.but i dont know how they would hold up baling 700 or 800 bales.you would be better off stepping up to the 605 baler.
   / Vicon RV 1601 or Vermeer Rebel 5500 #3
if I was on the fence i would ask myself about service first, both are good balers, in my opinion the Vermeer is easier to work on, and a fairly simple machine and will bale anything I put in front of it!:thumbsup:
   / Vicon RV 1601 or Vermeer Rebel 5500 #4
The Vermeer 5500 Rebel make a 5.5 x 5 bale. It matches your 5610 tractor fine. Vicon sold less than 200 balers a year in the USA for the last 20 years. Vermeer has been selling 1500-2500 round balers a year during the last 20 years. Parts availability alone would make me choose the Vermeer if the price was close. Market for the 5500 Rebel should be $8,000-10,000. The baler sold new for $15,000-16,000.
So, do others agree 700 bales a year is a bit much for the Vermeer? How about the Vicon? Both seem to fall into the same price bracket so I assume the are close to the same durability.
   / Vicon RV 1601 or Vermeer Rebel 5500 #6
700 bales a year is nothing on a 5500 Vermeer. I have been custom baling for 25 years and 24 of thoes years with a Vermeer. My first Vermeer was a 505 Super I. Put 12,000 bales thru it with only one bearing problem. I also had a 555 XL similar to the 5500 putting over 16,000 bales in three and a half years thru it with only replacing belt lace several times. The last four years I have run a 605 M with a 605 Super M update roller kit putting around 3,500 to 4,000 bales a year thru it. I have run as many as 25 bales an hour thru it with a 145 hp tractor in front of it.
   / Vicon RV 1601 or Vermeer Rebel 5500 #7
I would buy the Vermeer,
and, it will handle a lot more than 700 bales per year.
Is there a brand you guys would suggest over the Vermeer? Or, is it basically down to taste when you start picking between the major brands?
   / Vicon RV 1601 or Vermeer Rebel 5500 #9
Taste. Personal preference. Whatever you want to call it.
For me, It's JD or Vermeer round balers.
Would the 5610's be enough to push a 6x4 or 6x5 Vermeer baler, or would that be pushing it a little too much when the chamber gets full and pulling up an incline?
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2011 GMC Acadia SLE SUV (A50324)
2011 GMC Acadia...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1CT2EFB75727 (A48836)
2014 Ford F-150...
LEEBOY 8520 APHALT PAVER (A51242)
LEEBOY 8520 APHALT...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52128)
2006 Magnolia Dry...
