No horror story here
   / No horror story here #1
LHS Inc
Gold Member
Eastern Shore, Maryland
JD 3520 eHydro w/300CX FEL
I've read about the horror stories on getting the blade bolts out on various types of rotory cutters so I decided to give mine a try.
My Frontier RC 1060 is a 2007 in very good condition. I bought it used just last Fall. The blades aren't that bad but I really wanted to get the bolts out.
I sprayed PB Blaster on them once a day for a week. I used a long pipe for leverage and the nuts came off and to my delight the bolts dropped right out with the blade for both of them. No beatin' and bangin' to be done here. You talk about happy, I sure was.
I know getting the blades and bolts back on isn't the easiest job in the world but if thats the hardest thing I'll have to do on the RC I'll be happy.
   / No horror story here #2
I read your thread earlier before I went to town, and decided to buy some. I bought a can of PB Blaster for $4.27 - 11 ounce can at Home Depot. I have always used Liquid Wrench or WD-40 in the past. Hopefully it works as well as your post indicated. Thanks for posting.
   / No horror story here #3
PB blaster is really good. I do a lot of mechanic work and I use it a lot. It'll really eat rust and loosen stuff up.
Glad to hear those blades came off. They can be tough.
Thanks guys for the replies. I think PB Blaster is good stuff. I always keep some on hand.
   / No horror story here #5
If that don't work try Kroil, Expensive but good stuff...
   / No horror story here #6
Never heard of that. Thanks. I'll check it out. I'm always looking for a better rust buster.... :)
   / No horror story here #7
I took two Harley transmissions from 1936 and a 1938 and let soak in kroil for a week and every fastner came right off. These two items were so incrusted with rust, you would swear they spent the best part of this centery on the bottom of a lake. Its hard to find and expensive but worth every penny to me..:eek:
   / No horror story here #8
I have real good luck with John Deere penetrating oil. I am sure John Deere doesn't make it. If I could find out who does I am sure it would be cheaper. I have sprayed stuff with wd40 and not had luck with it. Spray a little JD on it and let it soak for a few minutes and it comes loose.
   / No horror story here #9
+1 for Kroil.
1983 Grady-White 17ft Fishing Boat with T/A Boat Trailer (A50324)
1983 Grady-White...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR29J160609 (A51572)
2009 International...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A52576)
2013 PETERBILT 386...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52748)
2019 Energreen EVO...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
