Greasing Clutch and Brake Pedal (L3800)
   / Greasing Clutch and Brake Pedal (L3800) #1
Rail Dawg
The L3800 manual on the Lubricants, Fuel and Coolants chart lists the clutch pedal and brake pedal. Under Lubricants it says "Until Grease Overflows".
What do you think they mean? There isn't a Zerk fitting I assume. Do we just spray some grease on the moving parts?
Thanks.
   / Greasing Clutch and Brake Pedal (L3800) #2
Generally both will have zerk fittings, and you grease them until grease comes out.
   / Greasing Clutch and Brake Pedal (L3800) #3
There are two zerks on the center of the undercarriage. They are easy to see but you do have to crawl underneath. There is enough room to fit (just enough) under without having to jack anything up.
   / Greasing Clutch and Brake Pedal (L3800) #4
There are two zerks on the center of the undercarriage...
I think there are there's three (not two, left right and center) and they are normal grease zerks - easy to see the grease come out... just did mine last week. There are two for the front axle as well. I think I've mentioned this before... recheck the oil in the front axle since it's slow to seep in to the bottom.
2018 Infiniti QX30 Premium SUV (A50324)
2018 Infiniti QX30...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
2008 Ford F-250 Reading Service Truck (A50323)
2008 Ford F-250...
1997 John Deere 8100 MFWD Tractor (A52748)
1997 John Deere...
2016 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2016 Chevrolet...
P.T 1000 Gallon Supply Tank (A50120)
P.T 1000 Gallon...
