Missouri Pioneer
Gold Member
Scenario: 55 hp 4WD tractor, loaded tires, wt w/BB, over 9K. A couple of weekends ago, I began successfully pulling out up to 4" cedars w/a 12 lb. Brush Grubber HD. I also pulling several similar sized honey locust trees until the last, when the Brush Grubber bent.
Replaced the Brush Grubber w/same, plus bought a new Brush Grubber Extreme Plus (which is a real 36 lb. hoss). I'm looking forward to see what it will do in the next few days.
I have some larger sycamores which I want to remove before doing some dirt work this weekend. I would rather pull them, since they would still be in the way cut off at the current ground level. They are too big - perhaps 10-12" - to use the BG.
If I cut them off about 5 or 6' tall, I'm considering the possibility of attaching a chain near the top and using the leverage of the trunk to perhaps pull 'em over, but I don't want to damage the tractor or do something dangerous.
Is this feasible or a "forget about it" kind of thing? Thanks.
