3800 Antonio Carraro bi-directional
   / 3800 Antonio Carraro bi-directional #1
akerms
Antonio Carraro 3800
I have a Carraro 3800 bi directional tractor. It is a fantastic bit of gear for general small farm operation. Just one issue, which is the temperature that the gauge runs at when pto engaged.
I've been using a slasher in normal forward motion, and a finishing mower in reverse mode (so the mower is out front when operating). In both cases, as soon as there is a little bit of load on the slasher/mower, the temperature gauge runs up to just at the top of the green band, and occasional into the red. The overheat warning light has come on once or twice.
When the gauge is right at the top of the green band, I can comfortably leave my hand on the radiator and also top of the engine without getting burnt, so I'm wondering whether it is just the parameters of the gauge. I've spoken to the local tractor mechanic and he indicated that the European tractors generally only have a radiator just big enough. The radiator is clean and I maintain it clean throughout operation. I'm in central NSW so it can get a bit hot, however have been operating it when the outside temperature is something between 10 to 20 degrees C.
Has anyone else had experience with either the 3800 or its replacement the 4400 and the operating temperature. I'm just trying to work out whether the gauge is operating normal, or there may be some problem (buggered bearing etc) in the direct drive PTO shaft that is meaning that the engine is under more pressure than when the tractor is just operating in hydrostatic mode. Any thoughts would be greatly appreciated.
Update:
All fixed, $20 thermostat. Running 6ft mower at 1/2 temp - can comfortably leave hand resting on top of engine block no problem after an hour of mowing. Simple solution.:thumbsup:
   / 3800 Antonio Carraro bi-directional #3
Update:
It's good to see that you got fixed so easily and inexpensively. I'm sure you know that your tractor is a rather rare beast. Maybe that's why you didn't get responses to your earlier post.
Can you post a photo or two of it?
2009 DRAGON  130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53473)
2019 Krause...
2006 TEREX OEGSIB 1412 TRAKPACTOR (A53426)
2006 TEREX OEGSIB...
2017 Volkswagen Golf (A51694)
2017 Volkswagen...
Unused 2025 Bale Spear Skid Steer Attachment (A51691)
Unused 2025 Bale...
