Rebuilt 4630 wont start but smokes
   / Rebuilt 4630 wont start but smokes #1
timbeall1
ford 4630
I've compleatley rebuilt the 201 diesel engine in a friends 4630 tractor. with ample cranking speed, new fuel, and working injection pump. i cant get it to start, only blow diesel smoke out of the exhaust. everything is timed according to the manual. and will crank witha small shot of ether. any help would be appreciated. thanks
   / Rebuilt 4630 wont start but smokes #2
the rings probably or not seated yet and needs to run and work it for a while
yes sir, but the problem is that it wont run at all. I should have been clearer in my description. What i meant to say was, as i turn the engine over it blows plumes of unburnt fuel out of the exhaust, the only time this engine has fired, it was with the use of eather. but it only runs off that for a couple seconds. thanks
   / Rebuilt 4630 wont start but smokes #4
Assuming there are no assembly issues and the cam timing & valves are proper set I would say the injection timing is off. If there is compression & the injection timing is correct it has to run.
I would recheck the injection pump timing again.
90cummins
   / Rebuilt 4630 wont start but smokes #5
what year model 4630 the later ones also had a timing inside to pump that if you didn't look the pump and removed to pump you must put the pump and a stand and flow time it
its a 94, never looked in the pump, i'll have to check it out
   / Rebuilt 4630 wont start but smokes #7
just for the heck of it.. did you comp test it?
No sir, I got it running last night but but it was missing on the #1 cyl, and smoked heavily, i ran out of daylight befor i could swap holes with the injector to see if the miss would move or stay with #1, But ill let you guys know what i find. Thanks for the help.
   / Rebuilt 4630 wont start but smokes #9
keep us posted.
UNUSED SDLANCH HYD MINI THUMB CLAP7P (A57193)
UNUSED SDLANCH HYD...
UNUSED FUTURE XJ5T-5T HYD THUMB CLAMP (A57193)
UNUSED FUTURE...
2011 Chevrolet Equinox SUV (A53424)
2011 Chevrolet...
2005 Dodge Caravan Van (A54815)
2005 Dodge Caravan...
UNUSED FUTURE BC63 57" HYD BRUSH CUTTER (A57193)
UNUSED FUTURE BC63...
