3-Point Hitch Kubota L4400 Slow Lift
   / Kubota L4400 Slow Lift #1
RockyCreek
2006 Kubota L4400
Hello I have L4400 and my lift had gotten slow to go down I changed the Hyd. Fluid and filter but it still is slow to go down without some heavy weight on it like a disc. It's ok picking it up. Any one knows what is causing this?
   / Kubota L4400 Slow Lift #2
Check the round knob in front of and below your tractor seat. I have hit mine an few times and run into this issue. This is a 3PH speed control. :thumbsup:
   / Kubota L4400 Slow Lift #3
Ditto:thumbsup:
There should be a round knob under the seat. It is the drop speed control.
It is adjustable because if you set it to lower something like a 300lb blade at a decient speed, lowering a 1100lb bushhog is going to be like free falling:confused2:
Ok thanks I will check that. I have another question for you guys my fuel gauge quit working I only have 259 hrs on my Kubota do y'all know of what could have caused it to quit?
   / Kubota L4400 Slow Lift #5
I doubt they are related. The lift is hydraulic issue and the fuel gauge is electrical. For the fuel gauge I would start by checking the connection to the fuel sending unit.
2006 Kubota L4400, 259 hrs, with loader, excellent condition, shed kept, not HST standard trans. Asking $16,000 to sale what y'all think is this a good
Fair price?
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A57453)
(1) HD 24ft Free...
2- 5TH WHEEL PLATES (A58216)
2- 5TH WHEEL...
2007 JLG 600S Manlift (A57453)
2007 JLG 600S...
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
2006 FRAC TANK 500BBL WHEELED (A58216)
2006 FRAC TANK...
2019 GALYEAN...
