L3240 vs. L4400
   / L3240 vs. L4400 #61
The R1 ag tires can be set out to about 74 inches outside to outside. The front are not adjustable.
Can the fronts be swapped sides and gain a little??
I dont have a L4400, but on my 3400 the offset of the rims is about 1" different. So if you turn them around and swap sides, you gain about 2" each side.
Does anyone have an opinion of how handy the back smart hitches are and to which equipment would one use the male part mainly?
And how about the the FEL Tooth Bar Teeth...how handy are they and are they a hinderance sometimes...
Teeth are very handy if you plan on doing any digging with the FEL. Not really needed if you are only scooping loose piles. Like gravel, sand, mulch, piles from the BH, etc. But if actually digging soil with it, the teeth are nice.
I cant comment on any of the quick hitch/ smart hitches. But, I dont like the ones that are all one peice that includes a big hook for the TL. Because All of my implements are older and used, and not all the same spacing. So one of them wouldnt work on all I got.
And I am old school. For me, hooking up implements isnt hard at all. But If I did get something, I would probabally consider the hooks that get welded on TOP of the 3PH arms. I cant remember but I think either carter or haytools makes them. Similar to the pats system, only you dont make the lower arm "longer" by putting them on top.
   / L3240 vs. L4400 #62
The L4400 has the same set up and it is tempting to turn them around but according to the owners manual it is not recommended. Others have went ahead and reversed the rims and suffered leaky seals from the added stress,:thumbsup:
   / L3240 vs. L4400 #64
I see.
I guess I never read my manual:confused2:
Mine on my L3400 have been turned around since I got it. No issues but I only have ~300hrs in 6 years.
2025 SDLANCH SDLGC80 UNUSED Electric Golf Cart (A53117)
2025 SDLANCH...
2003 Chevrolet Silverado 2500HD Pickup Truck (A53117)
2003 Chevrolet...
CUSHMAN SHUTTLE GOLF CART (A51406)
CUSHMAN SHUTTLE...
2016 Dodge Charger SRT Hellcat Sedan (A53424)
2016 Dodge Charger...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
