Found a pretty good sized Roller. Whats it worth?
   / Found a pretty good sized Roller. Whats it worth? #11
I'm In Doylestown and a local Custom Builder and could use this for my Lots
on my rough grades if you are intrested in selling please contact me!
Reminds me of the roller I used as a kid to roll the soccer fields in the 1970's
The concrete and casing were done in the same fashion.
   / Found a pretty good sized Roller. Whats it worth? #12
You guys are quick! Made it out like this: 26"x1/4" wall steel pipe is 68.8#ft, The volume is Radius Squared X Length = 31855.83 cu in. A cubic ft of concrete is 145#. Divide the 31855.83 x 1728 = 18.43 cu ft in the roller. So 18.43 X 145# per cu ft = 2673#. Plus the pipe if it's 26" = 344# .........
Looks like 3,000 pounds to me also............~Scotty
The concrete was the done in the same fashion.
we may be in touch soon buddy
this math is crazy lol. are you serious though? is it about 3thousand pounds? thats what it sure as **** feels like. at least that. if it sits in one spot over night it sinks into the ground
   / Found a pretty good sized Roller. Whats it worth? #15
Problem is that nothing needs rolling on my property. its pretty flat and my driveway is paved.
3klbs. Now you KNOW WHY AND HOW your property is so flat!!!! :laughing: :D :laughing:
   / Found a pretty good sized Roller. Whats it worth? #16
Ohio Steel sells their 60"x24" roller for $379. Filled with water it weighs 1150 pounds. Could you tell me what type of bearing or bushing you have on the ends? Thanks.
   / Found a pretty good sized Roller. Whats it worth? #17
Water weighs about 62.5 #per cu ft if anyone wants to do more calcuations. :laughing: ~Scotty
   / Found a pretty good sized Roller. Whats it worth? #18
Well that 2'x 5 ' column is 15.7 cubic feet and 117.5 gallons.
So 15.7 X 62.5 = 981 lbs. just for the water, so what TXDon said sounds right.
JB
   / Found a pretty good sized Roller. Whats it worth? #20
The Tractor Supply 52" (overall) Roller is actually a 48" Roller. The extra 4" that they measure is the 2" shaft and angle iron that is on either end.
Their 60" roller (overall 64") Ohio Steel Roller is $399. It is not on line but I went to their store and they looked it up in their book.
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
2020 FREIGHTLINER M2 SINGLE AXLE BOX TRUCK (A54607)
2020 FREIGHTLINER...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2019 Allmand Maxi-Lite II 15kW S/A Towable Light Tower (A52377)
2019 Allmand...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A55218)
1992 Talbert 70...
