Ford Powermaster Pictures
   / Ford Powermaster Pictures #1
jon1996
Hey folks,
I am in need of some Powermaster pictures, I have a 821 backhoe and its missing the part of sheet metal that covers the steering colum right under the dash, and also I would like some pictures of the power steering lines and cylinders, Mine has brakeline and I just dont think that is factory because they curve out to far, also any other pictures of a restored tractor would greatly help, I am working on the wiring right now but I took it all out and I am just going to wire it the way it should be, Its such a simple system
   / Ford Powermaster Pictures #2
I just got on Google and typed in "Pictures of Ford Powermaster" and there are quite a few pictures. You Tube has several videos of these tractors. Hope this helps somewhat. Good Luck.
I did the same and none of them show the metal I need and none of them are close up enough, I am in the tear down right now got all the sheet metal off but will need to know what that piece looks like before I go back with it so I can build one
Thanks
   / Ford Powermaster Pictures #4
Thanks
pm soundguy he owns about 100 of them i believe (no really he only has about 10) but im sure he has some pictures of the tore down and fully assembled
anybody else? no ones got close up pics of these tractors in detail?
   / Ford Powermaster Pictures #6
closer to 20 actually.. but yeah.. plenty.
To the OP.
brake line is a good substitute.
the oem lines get damaged frequently,. and brake line looks better than hoses.. etc..
i'll dig up some pics of the cowling. I have fords with ps.. but no pics of the lines. I'll grab a diagram off the parts catalog though.. note: 2 pump setups depending upon sn...
post back if you need more pics.
thise pics are from different 55-64 machines.. but hood at the dash and cowling are pretty much the same for all straight gear models...
   / Ford Powermaster Pictures #7
here's another close up of a dash cowl.. this one is a 951
   / Ford Powermaster Pictures #8
need any more.. just pm me.. or reply back here
i have pics of most of these 53-64 fords in various states of assembly
   / Ford Powermaster Pictures #10
over half of em are rocrops.. I seem to have a likin' to them.. especially the trikes..
even the non fords I have .. all but 2 are row crops...
I officially ran out of barn space this am. have already got the horse barn and long metal equipment shed full.. plus 3 outbuildings. if I get another.. 'll have to add on a wing.. :)
soundguy
2019 INTERNATIONAL LT625 SLEEPER (A45046)
2019 INTERNATIONAL...
Set of (3) 11L-15 Uni-Lug Rims and Tires (A49339)
Set of (3) 11L-15...
Kubota TE4052T Hay Tedder (A47307)
Kubota TE4052T Hay...
KC 28in.x90in. Metal V Bottom Feed Bunk (A46502)
KC 28in.x90in...
Roller Inspection Table (A47369)
Roller Inspection...
AGT Industrial QK16R Mini Excavator (A43476)
AGT Industrial...
