Alternator for 6610S
   / Alternator for 6610S #1
M16
New Holland 6610S
Do they make an alternator that will fit the 6610S that doesn't need the battery temperature sensor. If so what is the model and where can I find one. I am having constant problems with the sensor and the battery doesn't get charged. A rat chewed the wires on my last one and they are 60 bucks to replace.
   / Alternator for 6610S #2
The temperature sensor is most likely a resistive device, and if you can find what the resistance should be for normal operation, you can just mount a regular resistor up by the alternator and it will think the temperature is fine.
   / Alternator for 6610S #3
Go to radio shack and buy a 200 ohm resistor and wire it in instead of the temp sensor.
2016 WESTERN STAR 4900 SB DAY CAB (A58214)
2016 WESTERN STAR...
2014 Toyota Camry Sedan (A56859)
2014 Toyota Camry...
2005 CHANDLER 500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
Giyi Tree Sheer (A57149)
Giyi Tree Sheer...
2005 Jeep Wrangler 4X4 SUV (A56859)
2005 Jeep Wrangler...
SHOPMADE MANIFOLD TRAILER (A58216)
SHOPMADE MANIFOLD...
