HYD remotes on JD 4000 and 4020
   / HYD remotes on JD 4000 and 4020 #1
1010
Gold Member
MS
JD 4000 sold now a 2015 5075E
I have a 72 model JD 4000 with a single HYD remote. I have found a 4020 that I can get another HYD remote off of cheap.
My question is other than the linkages will this bolt right up to my tractor?
My tractor has a plate where the second remote goes. No linkages
Please reply with ANY info you have, on this addition.
thanks DAVID,
   / HYD remotes on JD 4000 and 4020 #2
When you search JDparts.com for 4000, the catalog it takes you to is 4000 and 4020 Tractors. Selective control valves in this catalog do not specify for only one model. So I say it will work
   / HYD remotes on JD 4000 and 4020 #3
I assume the 4020 donor tractor is serial number 201,000 or higher. If so then it will work. The linkage should also switch over. I assume the remote you currently have is on left side. To install the remote on the right side, you need the plate from a tractor that has a remote on right side also. BE careful when removing you existing plate. There are springs and valves behind it for the three point valve. Make sure the three point is down before removal or it will suddenly drop and you will get oil bath in the process.
Is the remote self contained and just bolts up?
Will I have to take the remote insides out to remove it?
I have seen the valves and springs on a break down of the remote.
   / HYD remotes on JD 4000 and 4020 #5
Good advise here. The SCV assembly complete with couplers will bolt right up. You probably will want to replace the two seals/quad rings at the interface.
If the donor 4020 is below s/n 201000 with hyd levers to the left of the steering column, the valves are different and won't work on your 4000.
   / HYD remotes on JD 4000 and 4020 #6
Here's a photo
Well It turned out the salvage tractor was a few years older than mine and the SCV were different.
If yall know of a place that has HYD SVCs for a good price let me know!
Thanks so much for the replies guys TBN rocks!!
DAVID,
   / HYD remotes on JD 4000 and 4020 #8
Larry Anderson in Iowa usually has some used late model SCV's for sale. His phone # is 515-290-4336. Tell him I recommended you call him.
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2022 CATERPILLAR 980 WHEEL LOADER (A52705)
2022 CATERPILLAR...
1979 MACK R MODEL WINCH TRUCK (A53843)
1979 MACK R MODEL...
2016 Freightliner M2 106 Ambulance (A53422)
2016 Freightliner...
