1533 Engine Power Loss Intermittent
   / 1533 Engine Power Loss Intermittent #1
madmiller
Recently I my 1533 has been intermittently lossing power, mostly while in higher RPM. The engine has outright stalled a few times. Changed fuel filter and cleaned out sediment bowl and added dealer recommended D-Syl to help with water and to condition injectors. Still same problem. Any ideas? Thanks!
   / 1533 Engine Power Loss Intermittent #2
the mack dump truck i operate at work was doing something simular to that for the past 3 years (never stalled though). i first thought turbo, but the mechanics said no. so then change all fuel filters which seemed to help some, but still not quite. they just recently replaced all 6 injectors. that was a few weeks ago and so far no problem. don't know what might be wrong with your tractor, but just a story for your info.
   / 1533 Engine Power Loss Intermittent #3
Make sure you don't have something intermittently blocking your fuel tank outlet.
What ammbient temps are you running at?
In cold weather, water contaminated fuel can freeze on the fuel filter and using summer fuel without winterizing treatment can result in fuel gelling. Either of these problems can restrict fuel delivery to the injection pump and cause your syptoms.
   / 1533 Engine Power Loss Intermittent #4
Make sure the air filter is not collapsing. I've seen that happen when the pleats fold over and choke off the air supply.
   / 1533 Engine Power Loss Intermittent #5
have you checked if the spark plugs are tite and is have you checked the jets
excavator trenching bucket- one bucket per lot (A56435)
excavator...
2014 Ford F-150 Pickup Truck (A56858)
2014 Ford F-150...
2019 Chevrolet Tahoe (A55973)
2019 Chevrolet...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2010 International Derrick Digger (A55973)
2010 International...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
