small cabin
   / small cabin #1
barrentine
I have 30 acres in middle georgia and want to build a small cabin.I was thinking about building it with landscape timbers from Lowes.Has anyone ever done this?
   / small cabin #2
I don't know if they were actual landscape timbers... we stayed in a very small cabin that "looked" like they were made of them. They were stained brown and was pretty neat building.
A couple thoughts, landscape timbers always seem to be "cheap" wood, warps if not nailed down quick. They are pressure treated which some counties will not allow you to live in them. Not sure about the "new" pressure treated stuff.
How big of a cabin are you looking to build?
Google showed up with this:
http://www.jimdavidsoncolumn.com/timberhome/?type=building
   / small cabin #3
I think I would probably check into what chemicals they used to treat those timbers. Pretty nasty stuff.
   / small cabin #5
I think you should price other sources for your timber. I bet you could get higher quality and eliminate the treatment. It might cost more but your cabin will be arounda long time. Quality pays.
   / small cabin #8
There were plans that I saw for a kids playhouse cabin made out of landscape timbers, I cant find the link, but it was really cool looking.
   / small cabin #9
You'll never get them to stay straight, or seal up. I've seen them used for a shed and it was a mess.
If you want the look of logs without the expense or trouble of working with real logs, stick frame it, use fiberglass insulation, cover the walls with OSB, wrap with house wrap and side with log siding. It looks like real logs, staines the same too, but doesn't have any of the issues of real logs.
2x8x16 Log Cabin Siding #2 | Wood Pattern Siding
Eddie
   / small cabin #10
I agree with Eddie. If you want real logs, I wouldn't go smaller than 6x6.
If you are serious about a log home, whether siding with quarter logs or real logs, it would be a good idea to search the net. I would look at some one in your region if you can.
New Holland HM236 3pt Disc Mower (A50774)
New Holland HM236...
Toro Z Master Mower (A50324)
Toro Z Master...
2018 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52128)
2022 New Holland...
UNUSED SWICT 60" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 60"...
2015 CATERPILLAR 336FL EXCAVATOR (A51242)
2015 CATERPILLAR...
