Loader 1972 JD 300 backhoe and loader-hydraulic problem
/ 1972 JD 300 backhoe and loader-hydraulic problem #1
bpperk
JD 300 Backhoe Loader
Local cemetery has this tractor with a leaky loader control valve. Shop states that the valve is worn and not repairable. What valve will work as a replacement?:)
/ 1972 JD 300 backhoe and loader-hydraulic problem #2
:welcome:
Have you tried pulling the valve spools out to see if there are 0-rings that can be replaced? Some have them, some don't.
Are there two handles or one joy stick?
/ 1972 JD 300 backhoe and loader-hydraulic problem #3
2 different loader for this machine. The 7300 and 7320 loader. The 7300 had just a conventional remote mounted valve that should be easy enough to get an aftermarket valve if the leak is too much. Not much you can do with that valve other than toss it. The 7320 used a setup more similar to later model units that have a stacked valve formation but again not much you can do with those either both valves where class fit (individually matched spools to valve housing) but parts are still available although very spendy. Is the unit expensive vs the amount of oil it is losing?
I need to know, find out or be told, what the flow and pressure that this loader is designed for. That way I can get a proper replacement. Thanks for any help that you can offer.
The valve is worn so badly that it cannot be rebuilt.
This is a joy stick control. We tried a replacement valve (generic) that a local hydraulic shop supplied. The flow seems to be restricted. We tried the new valve in open center mode and closed center (power beyond) mode with the same result. How any gallons per minute does this sytem have the capacity to displace?
/ 1972 JD 300 backhoe and loader-hydraulic problem #7
This is a closed center system. Hyd flow when new should have been about 18 gpm, 2250 psi max.
I had this system checked out today at a reputable truck repair shop where they have the ability to check pressure and flow. They state that the original equipment valve, tested on the tractor, flows 22 gpm at 2900 psi. Also that this is a open center system. The JD manual that we have for this unit states that the valve has two relief valves. One is set at 1500 PSI and the other at 2750 psi. Could this mean that the flow throught the valve is through the 1500 psi circuit and that when the lever actuates a circuit the valve changes to the 2750 psi relief? I appreciate everyone's help. There are no JD mechanics around here that are able to remember how this system was designed. Thanks
/ 1972 JD 300 backhoe and loader-hydraulic problem #9
The truck repair shop is incorrect. There were no open-center hyd JD 300's built. All were closed center. Normally 2400 psi is the maximum the stand-by psi should be set or seals/o-rings will begin to blow. This is from Tractordata.
Type: closed center
Capacity: 10 gal [37.9 L]
Pressure: -unknown-
Valves: 1 or 2 optional
Total flow: 6.5 gpm [24.6 lpm]
13 gpm [49.2 lpm] (optional)
23.5 gpm [88.9 lpm] (optional)
Now it is getting interesting. The parts book for this loader on JD 300 tractor with 7320 loader (PC-1111-(May-69) shows one relief valve. The JD operators manuel for the JD300-A and JD400-A (OML27245 Issue A1) shows a picture of the valve for the 400 series and states that the valve has two reliefs. Are the 300 series and the 400 series valves the same?
In your previous post you give values that are considerable different from what the truck repair garage determined. From what source did you get those values and is there more information with that source or reference that would help me??
BTW this is a commercial (yellow) backhoe/loader. I may have mislead you by not stateing that earlier.
/ 1972 JD 300 backhoe and loader-hydraulic problem #12
After being employed at a JD dealer for over 20 yrs('66-'87) I know that JD 300 tractor is painted ind. yellow from the factory and is indeed closed-center hyd's.
I got the stat's I posted from "Tractordata.com"
This is what the hyd pump should look like in a 300
/ 1972 JD 300 backhoe and loader-hydraulic problem #13
If the hyd system is closed center, the 1700 psi is probably the accumulator pressure cut on psi. The unloader circuit would bring the pressure back up to the operating pressure.
Hydraulics:
Type: closed center
Pressure: -unknown-
http://www.tractordata.com/industrial-tractors/000/0/1/10-john-deere-300.html
/ 1972 JD 300 backhoe and loader-hydraulic problem #14
According to JDparts.com(parts cat #1111 - JD300 (7320) Loader - 07Nov01) the relief valve in a 300 with a 7320 loader the relief valve AU40752 is used in these models which includes 400.
932 - 92 Backhoe (use with JD300 and JD400 Loaders and with 1010 Wheel Loader) - 30Aug01
980 - JD400 and JD401A (7400) Loader - 07Nov01
1032 - JD500 Series A (-123113) Backhoe Loader - 06Jul06
1068 - JD544 and JD544A Loaders - 06Jul06
1105 - 9250 Backhoe (for JD300 Tractor and for 350B and 450B Crawlers) - 30Aug01
1110 - JD644A Loaders - 15Jul05
1128 - JD500 Series B Backhoe Loader - 02Nov06
1176 - JD500-A (123114-152141) Backhoe Loader - 06Jul06
1226 - JD310 Backhoe Loader - 03Nov06
1227 - 410 Backhoe Loader - 03Nov06
1239 - 500C Backhoe Loader - 07Nov06
1240 - 510 Backhoe Loader - 29Aug06
1297 - JD740 Skidder - 03Nov06
1403 - 544B Loader - 18Jan11
1404 - 644B Loader - 18Jan11
1419 - JD740 Grapple Skidder - 06Nov06
1428 - 300B Loader and Backhoe Loader - 26Mar08
1431 - 401C Loader and Backhoe Loader - 19Jul05
1433 - 302A Loader and Backhoe Loader - 16Jun06
1481 - 646 and 646B Compactors - 06Nov06
1518 - 640 Log Skidder and Grapple Log Skidder - 30Aug06
1524 - 540B Log Skidder and Grapple Log Skidder - 05May06
1571 - 743 Tree Harvester and Feller-Buncher - 21Oct08
1583 - 444 Loader - 06Nov06
1725 - 740A Log Skidder and Grapple Log Skidder - 21Oct08
1792 - 743A Tree Harvester and Feller-Buncher - 21Oct08
1883 - 401D Tractor - 29Sep05
1930 - 310A, 310B Backhoe Loaders - 16Jun06
1977 - 540D Log Skidder and 548D Grapple Log Skidder - 07Dec06
1978 - 640D Log Skidder and 648D Grapple Log Skidder - 07Nov06
/ 1972 JD 300 backhoe and loader-hydraulic problem #15
J_J
What are you referring to as the "accumulator pressure cut on psi" & "unloader circuit"? Closed center hyd systems such as the JD 300 have stroke control & pressure control valves. Parts keys # 42,43 & 44 comprise the stroke control valve in the larger pump in a 300 in the photo
Getting back to my original problem with my yellow iron. The factory assembled this loader (7320) with a valve that has two reliefs. A newly purchased and hydraulic shop recommended a dual spool valve that is rated at 20 gpm operating in closed center manner at less than 3000 psi stresses the engine so much that the tractor wil not motivate down the road and heats up. The rpms will not tach up and the engine sounds labored. What type of valve can be used as a replacement that will let us enjoy our yellow iron to its fullest capacity? Engine was professionally rebuilt recently. With the original, leaky valve the machine operates as it should. Please help, as I really appreciate the help.
/ 1972 JD 300 backhoe and loader-hydraulic problem #17
Getting back to my original problem with my yellow iron. The factory assembled this loader (7320) with a valve that has two reliefs. A newly purchased and hydraulic shop recommended a dual spool valve that is rated at 20 gpm operating in closed center manner at less than 3000 psi Please help, as I really appreciate the help.
First thing does the "new valve" have built in relief valves? If so they could be popping open at a pressure lower that the stand-by pressure is set. 2nd thing I would do is disconnect the the newly installed valve "return hose" at reservoir and aim this hose in the hyd filler hole and start engine. If oil squirts out of hose either the relief valves(if equipped)aren't holding stand-by psi or valve is an "open center not a closed center valve". As far as relief valves go on a closed center system they are only required to help keep from bending parts on things such as backhoe. HTH's,Jim
PS: My purpose for posting photo's of other hyd components was to try and "explain a closed center system"
The new valve has one relief. It is adjustable externally and is located nest the input spool. I don't understan the theory of the old valve having two reliefs. What is making the engine labor so hard? I appreciuate your insight.
/ 1972 JD 300 backhoe and loader-hydraulic problem #19
If the NEW valve is bypassing enough quantity of oil such as a bypassing relief valve or an open center valve it can cause the hyd pump to load engine. Did you do the checks I suggested?? If not then we can discuss this till the HOT place opposite from Heaven freezes over and not arrive at a resolution. If you would like to call me my # is 8one7*five1seven*1five9
zero.Jim
Jim,
I have not done the checks yet. The tractor is in use much of the time and when we can get it freed up I will do the things you mentioned and see what the result is. One of your posts indicated the flows and pressures that included two options. I would guess from what the truck repair garage found out that we have the larger pump option. Also when I went personally to the garage and inquired about the open center/closed center issue they indicated that it is a closed center system. I may have heard them incorrectly when I thought they indicated an open center.
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
WIGGINS 5K FORKLIFT (A58214)
WIGGINS 5K...
2014 Bobcat T550 Compact Track Loader Skid Steer (A59228)
2014 Bobcat T550...
1660 (A59213)
1660 (A59213)
2016 FREIGHTLINER CASCADIA SLEEPER (A59905)
2016 FREIGHTLINER...
2025 Safety Basket Forklift Attachment (A59228)
2025 Safety Basket...
