1990 John Deere 955, left brake stuck
   / 1990 John Deere 955, left brake stuck #1
ticowannabe
1990 John Deere 955
When I move forward it seems that the left brake is stuck, so much that if I continue engine will die under the load. Doesn't seem to stick in reverse. Any suggestions would be appreciated. At the moment I can't move the tractor.
   / 1990 John Deere 955, left brake stuck #2
The brake lining has probably delaminated from the shoe and is piling up under the lining on the other shoe.
Thanks RickB, but it's a hydrostatic trans and has no brake shoes. I appreciate your reply nonetheless. Scott
   / 1990 John Deere 955, left brake stuck #4
OK, you have wet disc brakes. Check the operating shaft and see if it is seized to the cover where it enters the brake housing. It should have several degrees of relatively free travel matching the pedal freeplay spec in your operator's manual.
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2019 FREIGHTLINER...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
