What are the options on removing paint?
   / What are the options on removing paint? #11
Texas Blaster it. I wasted a ton of time and effort doing it myself. Never again, I will find a pro to do it. .
many of us find doing the work ourselves is part of the restoration process, and part of why we do it.
anyone can buy a tractor and have someone else restore it.. ;)
soundguy
   / What are the options on removing paint? #12
Stripped many a corvette with aircraft stripper and acetone. At least on the back hoe, you don't have to worry about the underlying gel coat.
I think the backhoe will be easier than the FEL the FEL has tons of hard to reach places, Its gonna be a long ordeal to get it stripped and ready for primer, I knew that when I got it, But I think once done right it will be worth it, it runs so good and it will dig all day at idle if you want, its just a cosmetic issue
   / What are the options on removing paint? #14
take yer time.. work on a piece at a time...
   / What are the options on removing paint? #15
Oven cleaner
Don't laugh guys.
I use it often for small things and also it subs for carb cleaner.
Great also for fireplace doors and even my andirons.
Recently I stripped a piece of furniture with oven cleaner as well.
   / What are the options on removing paint? #16
If just brushing it on doesnt work fast enough, put some masking plastic on it for about an hour then scrape it.
I have stripped a few light aircraft in the past.
We always covered with plastic film so that the aeromatics would not evaporate as they are what does the job.
Scuffing is a big help also.
I would always buy the smallest qty sold of different brands of stripper in order to do test strips as different brands/formulas would have different effects depending on the paint used.
Just pray that it is not lacquer as only thinner will be effective.
You can protect any rubber (hoses) by wrapping with foil tape.
Around here we have a shop that you DIY the job using their air and equipment for $40/hr + sand you consume @ $7.00 per bag. I did my 60" snow blower for a total of $70. ish.
They provided 2-300 CFM's of air for great results.
Even used them to blast some furniture and wrought iron patio sets.
Some rental yards also rent 100-150CFM compressor rigs as well as sell the media.
(did a complete log cabin 30' x 40' in one day with such a rig.
INMO blasting is the way to go. Besides in a day you could probably blast a couple of your tractors as well as the BH. Just cover all engine parts very well with blankets or wrap and tape with HD poly. Duct tape is perfect for protecting glass as sand bounces off.
With a good setup it is awesome to watch bare metal make appearance as if magic
BUT----prime it FAST as 8 hrs later it will look rusty.
In other words, blast with the left hand and prime with the right LOL>
And I'll add, Boy does paint adhere to a blasted surface! Even my 5 year old snow plow (and blower) still look great. The paint sure sticks.
   / What are the options on removing paint? #17
The oven cleaner does do a nice job on truck frames. Replaced a worn out bed on a dually. Six cans of oven cleaner from the dollar store. Car wash. Repainted with a brush and one gallon of Rust proof high gloss black enamel. Dump bed sets up high and frame, axle, springs and other looks good. Cheap to do at under 50 dollars.
   / What are the options on removing paint? #18
soundguy
I agree.
   / What are the options on removing paint? #20
A neighbor who restores old JD's buys oven cleaner by the case at the Dollar General Store. He applies the oven cleaner and then uses a high pressure washer. I don't think any grass will ever grow behind his shop where he cleans the JD's at.
JOHN DEERE 7210R TRACTOR (A54756)
JOHN DEERE 7210R...
2025 Swict 60in Bucket Skid Steer Attachment (A53421)
2025 Swict 60in...
2018 MACK CHU613 DAYCAB (INNOPERABLE) (A53843)
2018 MACK CHU613...
Club Car Electric Utility Cart (A55853)
Club Car Electric...
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
2430 (A51248)
2430 (A51248)
