FOURTEEN
- Joined
- Jan 17, 2004
- Messages
- 1,042
- Location
- Efland - Triangle of North Carolina.
- Tractor
- 2004 Power Trac PT-425
When the OEM PowerTrac muffler died, I designed and installed a DUAL EXHAUST system to run quieter, sound better, get that major heat generator out from under the hood, blow exhaust away from operator, and have the mufflers farthest from the operator!
The exhaust is 1" galvanized rigid pipe.
Cut off old muffler leaving ~3" stubs.
6" Pipe slides over Stub; Elbow; 5" pipe; Elbow; 21" Pipe; Muffler.
Support near Muffler with 1" Pipe U-Bolt and Spacers through frame. (1/4" to 3/4" clearance from Pipe to Frame.)
Tack weld Pipe to Stub. Remove. Weld Pipe to Stub. Reinstall.
Cut ~2" hole with hole saw in bottom edge of cover to clear the Pipe.
Same on other side!
Recycle OEM Muffler as boat anchor!!
Same on other side!
