Pintle Hitch For Draw Bar
   / Pintle Hitch For Draw Bar #1
stickfarm
Georgia
John Deere 5101e ltd
Just purchased dump wagon which runs on tractor hydraulic lines. The wagon has a pintle or military style hitch setup. I would like to find a pintle hitch that would just bolt or pin to the tractor draw bar. Do they exist? Anyone have a better idea?
Thanks
Steve
   / Pintle Hitch For Draw Bar #2
   / Pintle Hitch For Draw Bar #3
You could buy one with a square shank, drill holes, and bolt it to the drawbar.
Bruce
   / Pintle Hitch For Draw Bar #4
The easiest thing to do is buy or build one of these. Or you can buy a receiver hitch like the pictures above and weld two bolts on the bottom to match the holes in your drawbar and bolt it on...
Trailer Mover, For Tractor - No Receiver
Wagon rated for 5 tons. With all that weight on the back while dumping, the 3-point hook-up will raise. I need to be on the draw bar and strong. In a perfect world I would have a 2x2 hitch that would bolt or pin on. Does anyone know someone who makes that?
   / Pintle Hitch For Draw Bar #6
you could weld up a sleave out of 3/8" metal that would slide over your drawbar and pin in place and bolt a hitch on like jpm1 pictured.
   / Pintle Hitch For Draw Bar #8
You could buy another drawbar and a reciever tube and weld it stright to the bar. A tube is only $20, an extra drawbar $???
   / Pintle Hitch For Draw Bar #9
What you want is something like this which allows you to open and close the hitch without leaving your seat (small black lever and cable). Very strong and cannot go up when the trailer unloads.
   / Pintle Hitch For Draw Bar #10
So go to a 2" receiver on your 3pth, but RAISE the hitch before you start to dump. Once its up, won't go any farther without lifting the tractor....
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
2014 Ford F-150 Ext. Cab Pickup Truck (A55788)
2014 Ford F-150...
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
2008 Ford F-250 Reading Service Truck (A55788)
2008 Ford F-250...
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A55218)
2015 Freightliner...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2018 FREIGHTLINER...
