Tractor tire goo
   / Tractor tire goo #1
remington270
Alabama
Kubota M7040, Kubota B2710
I have a little tractor that I use every few months and always seems to have a slow leak, what is your favorite "tire goo" or other option?
   / Tractor tire goo #4
Tubes if you want a permanant fix.
   / Tractor tire goo
I have tubeless tires, can you just add tubes, or does that mean whole new tires?
   / Tractor tire goo
Ok how does this stuff go in? Do you have to remove the valve stem? I guess this would fully deflate the tire.
   / Tractor tire goo #8
Yes the valve must be removed
Depending on the size of the tire, it's either put in with a squeeze bottle or pump.
   / Tractor tire goo #9
Had a slow leak in the rear tire of the Gator, finally took it off to check where it was leaking. I found that the tire was leaking all the way around the circumference, right where the flashing from the press/mold was. Odd, never seen that before. I was going to to tube it, but decided to try a bottle of Slime instead. Never used the stuff before. So far, so good...
   / Tractor tire goo #10
I use slime in my front tires on my tractor, and in all of my low pressure tires, gator, aircraft, and it works pretty good. I only add the occasional amount of air. If you can access nitrogen it works better than air as it does not expand and contract as much as air.
2012 Kia Sorento (A51694)
2012 Kia Sorento...
Cruise Car Electric Utility Cart (A51691)
Cruise Car...
2021 Liebherr L556 (A52748)
2021 Liebherr L556...
2021 Kubota SVL97-2 (A50120)
2021 Kubota...
20' Shipping Container (A50121)
20' Shipping...
2020 Chevrolet Tahoe SUV (A50324)
2020 Chevrolet...
