Tractor tire goo
   / Tractor tire goo #1
remington270
Alabama
Kubota M7040, Kubota B2710
I have a little tractor that I use every few months and always seems to have a slow leak, what is your favorite "tire goo" or other option?
   / Tractor tire goo #4
Tubes if you want a permanant fix.
   / Tractor tire goo
I have tubeless tires, can you just add tubes, or does that mean whole new tires?
   / Tractor tire goo
Ok how does this stuff go in? Do you have to remove the valve stem? I guess this would fully deflate the tire.
   / Tractor tire goo #8
Yes the valve must be removed
Depending on the size of the tire, it's either put in with a squeeze bottle or pump.
   / Tractor tire goo #9
Had a slow leak in the rear tire of the Gator, finally took it off to check where it was leaking. I found that the tire was leaking all the way around the circumference, right where the flashing from the press/mold was. Odd, never seen that before. I was going to to tube it, but decided to try a bottle of Slime instead. Never used the stuff before. So far, so good...
   / Tractor tire goo #10
I use slime in my front tires on my tractor, and in all of my low pressure tires, gator, aircraft, and it works pretty good. I only add the occasional amount of air. If you can access nitrogen it works better than air as it does not expand and contract as much as air.
2013 Mercedes-Benz C-Class C250 Sedan (A50324)
2013 Mercedes-Benz...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2019 Ford F-350 4x4 Ext. Cab Palfinger PSC 3216 4,000lb 2 Ton Mechanics Crane Service Truck (A50323)
2019 Ford F-350...
2015 Nissan Frontier SV 4x4 Pickup Truck (A50323)
2015 Nissan...
2012 Volvo XC70 Wagon Sedan (A50324)
2012 Volvo XC70...
