Hourly rate for backhoe work
/ Hourly rate for backhoe work #1
cat 297c
Gold Member
Semmes, Alabama
Cat 299D XHP, Cat 297c, Rayco C140
I've got a cat 416 have a customer wanting me to dig a hole an push a old barn in it wats the going rates for backhoe work, I just use it round the house never used it on any jobs before.
/ Hourly rate for backhoe work #2
I would check into this before you agree, there might be permitting required, liability insurance etc.
/ Hourly rate for backhoe work #3
Call 811 - Know what's below
Skip to Content. Why does this site appear as text-only? 811. Know what's below. Call before you dig. Always Call Before You Dig ..
Army Grunt
/ Hourly rate for backhoe work #4
Army Grunt
Excellent advice. Several years back a friend of mine worked for a Company in Florida. One of his fellow workers was killed when his boom came into contact with an underground electrical line.
/ Hourly rate for backhoe work #5
Not just permitting.
Pushing an old barn in a hole shouldn't be taken too literally.
Consider the amount of trapped air, HOWEVER carefully you back fill there will be sink holes a few years later.
I "might" be willing to dig a hole and bury the ASHES once the owner had burned it, but it would have to be BURNED and reduced to ash, not just the siding with framing merely charred, but ALL of it reduced.
/ Hourly rate for backhoe work #6
For a hoe and operator, I would say between 60 and 80 per hour.....don't forget transport.
/ Hourly rate for backhoe work #7
Well, looks like you got a lot of advice a month later. :laughing:
So how did it go?
/ Hourly rate for backhoe work #8
If I charge for my BH services my agent said my farm policy will NOT cover me so in my case I will just let them help with fuel cost but not quote them a rate.
If I was going to do it I would not touch it for less than $100 an hour (time based on time a professional operator would take) but that is not planned ever.
Done the job for 90 a hour finished in 6hrs she has me dig a stump after I finished the barn.
/ Hourly rate for backhoe work #10
Glad it worked out for you. :thumbsup:
HANG-ON TRACTOR 34" PALLET FORKS (A60430)
HANG-ON TRACTOR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
KUBOTA ZD1211 ZERO TURN LAWN MOWER (A60430)
KUBOTA ZD1211 ZERO...
2012 FORD F-350 XL SUPER DUTY CREW CAB SERVICE TRK (A60430)
2012 FORD F-350 XL...
5000 GALLON WATER TANK W/RELEASE VALVE (A60430)
5000 GALLON WATER...
