Good ethanol can run from $50 to $100 per gallon depending on purity and the reputation of the guy that made it..I can buy gasoline all day for less than $4 per gallon. I don't think you are going to want to be putting that in your cars tank. Besides when you starting buying that corn meal in any quantity.. well you see they monitor that, and the sugar you will need too. It is hard to keep these things secret. And a good copper worm is 2 inch copper coil and can really run up there in cost, nowadays. And you will need a good stream of water and a lot of propane to heat up your kettle. You could use wood, but it is going to have to be good dry wood, I am telling ya they are going to see the smoke. And I have heard they are using FLIR nowadays, to find you from the air.. Timber it just isn't worth it man. Too many risks and you can go to jail for a long time.. I advise against it. But whatever you think
James K0UA
