front diff both sides leaking gear oil GC 2310TLB 4WD
   / front diff both sides leaking gear oil GC 2310TLB 4WD #1
combanx
massey ferguson gc2310
Hi Everyone,
Just wanted to ask have any of you experanced both side leaking hydr fluid. Seems to be coming from where the joint is that the wheel turn on. Maybe there is a bearing or gasket in there somewhere, don't know. I know I filled it up this past summer sometime but never noticed it leaking. What would happen if I put too much in there, would it cause any damage. I wouldn't think so because there are only gears in there for the front wheel drive system. I parked it in the gargage and noticed this.
Any suggestions would be really helpful...thansk guys
reagrds
combanx
   / front diff both sides leaking gear oil GC 2310TLB 4WD #2
I know nothing about your model but the front wheel drive system on my Deere CUT will build pressure because it is a sealed system. Get it hot enough and it would blow out the seals. I drilled a tiny vent hole in the filler cap.
   / front diff both sides leaking gear oil GC 2310TLB 4WD #3
It's strange that it would be leaking from both seals. That would lead me to suspect the fluid.
What brand of fluid did you fill the front axle with? Some cheaper brands will thin out when they get hot orthe additives get used up and start leaking through the seals. Another way that may help is to replace the fluid with a suitably rated gear oil rather than the UTF.
   / front diff both sides leaking gear oil GC 2310TLB 4WD #4
My Kubota's manual recommends UDT OR SAE80 - SAE90 gear oil. I am currently using the UDT and almost always see a drop ready to fall from the case. This spring I will be draining and replacing with the much thicker gear oil and I suspect my leak will be gone.
   / front diff both sides leaking gear oil GC 2310TLB 4WD #5
Yes, you can put gear oil in the front differential, and most here recommend it.
It may help slightly with leakage issues. However, it is a misconception that 80-90 gear oil substantially thicker than the hydraulic fluid.
The hydraulic fluid is approximately a 10w30 viscosity and the gear oil tested on the same scale, is approximately a 20w50 viscosity.
You can visually see there is not a big difference, with a simple pour test.
Someone here once mentioned replacing front axle seals, and I recall that it was not particularly difficult, or expensive (on the tractor parts scale), to do.
   / front diff both sides leaking gear oil GC 2310TLB 4WD #6
I parked it in the garage and noticed this.
combanx
One other thing to check is if the oil is actually coming from the axles. If the loader lift cylinder hoses are leaking, the oil can fall directly on the axles. I had to replace all 4 of mine at c.300 hours.
   / front diff both sides leaking gear oil GC 2310TLB 4WD #7
I had the same thing happen to my 2310. I had to replace the seals.
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2017 Chevrolet Trax LS SUV (A55973)
2017 Chevrolet...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2015 Kia Sorento AWD SUV (A56859)
2015 Kia Sorento...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
