How do you recommend I plant bermuda?
   / How do you recommend I plant bermuda?
I like spriggs ... I always have better luck with them rather than seeds. Some folks think its hard to sprigg in fact it can be easy. I disk the area, go and buy quality square bales of bermuda hay break them up into the manure spreader and spread them out and disc them in ... pray for rain!!!
is it as easy as using bales of bermuda hay? could I rototill it in the cultipack it?
   / How do you recommend I plant bermuda? #12
Andrew, the bales usually look like any square bale of hay, but it's dug pieces with some root, so to speak. Not the same as hay, it is living rhizomes more or less. Rototill would work, but you may loose some that get buried to deep. I don't see a need for a cultipacker unless you just want to do it.
Break the bale up and throw the scattered around on disced or tilled ground.then disc in, or till if thats what you have, but till shallow, say 3-4".
2005 Interstate 7x14 Trailer (A55973)
2005 Interstate...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A57024)
Ditch Witch 6510A...
Engel 20' Boat (A50121)
Engel 20' Boat...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2019 Ford Transit Connect XL Cargo Van (A55852)
2019 Ford Transit...
16001 (A55853)
16001 (A55853)
