RDrancher
Today, on the second day of a 1,200 cubic yard landscape grading job I noticed a small leak around the final drive housing. I checked the tightness of all the bolts but within an hour it was a total mess. I couldn't really tell where the leak was coming from with all of the select fill dirt mixed in.
I pulled off the job and headed back to the shop to investigate. After removing the wheel I cleaned the final drive housing top to bottom but still couldn't find the leak. I replaced the wheel and drove it around and immediately found hydraulic fluid pouring out of the wheel flange shaft / seal area.
I drained the housing and removed the final drive cover along with the wheel flange and shaft. Removal was simple since it comes off as a unit. Inside the final drive housing I found metal chunks laying around the pinion gear and down in the pinion bearing area, so I removed the bottom housing cover and found quite a few metal shavings and more chunks.
Checking out the final drive gear assembly I found a shattered bearing race and keeper. The shaft spun nice and smooth, so if the seal hadn't started leaking I wouldn't have been aware of a problem inside. This could have lead to a very expensive repair.
Long story short, I took the assembly to my dealer who had it rebuilt with new style bearings and a new seal in less than twenty minutes. Noticed the leak at noon and had it back together by six and only missed a half day of work. Not too bad.
Thanks go to Messick's for their online parts diagrams and to McMasters New Holland for getting me back to work tomorrow. :thumbsup:
