3-Point Hitch lift capacity
   / lift capacity #1
6sunset6
SE NY
NH TC34DA 34HP HST, 2 rear remotes, front diverter, loaded R4's
Please hold the unrelated remarks.
Spec says 1635# 24" behind the balls.
What does this mean? At the ends of the lift arms or 24" further back.
   / lift capacity #2
24" aft of the lower link "eyeball" connections.
This is a very realistic way to specify lift, IMHO...since the weight of an implement is rarely at the 3PH hookup.
Just remember longer implements (rotary cutters are a good example) have a good percentage of their weight far aft of the 3PH.
   / lift capacity
Thanks. I have to move 60 yards of dirt about a 1000 yards, party on town road and the rest on a woods road.
Front bucket is kinda small. Dump trailer I don't have and don't want to build.
I was thinking of a rear bucket . maybe 1/2 yd sounds about right. Steel frame sort of like a pallet mover and just enough angle iron to hold plywood sides.
Dump with a hydraulic top link ,or enough angle to hoe it out. Maybe 3/4 yard or a little more both ends of the tractor .
I will move this to build it yourself when I get started. Oh yeah I have another tractor to load it, but it is a little old and I don't like to take it out on the road.
   / lift capacity #4
Sounds like a fun project, but depending on how much dirt you have to move, I think you'll end up using the loader. Just keep pleanty of ballast on.
You should be able to get ~1/3 yard in the loader, and it is easier to load and dump when you get there. No getting off to "hoe" it out.
But if you do build it, you could use both the loader AND rear scoop like you are planning. You will almost be able to carry a full yard each trip
John Deere 2040 Utility Loader Tractor (A55851)
John Deere 2040...
2014 Wacker Neuson BS50-4s Jumping Jack Plate Compactor (A55851)
2014 Wacker Neuson...
2025 Platform Safety Basket Attachment (A53421)
2025 Platform...
Case-IH 370 Steiger (A53314)
Case-IH 370...
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
