Oil & Fuel Oil and fluids - maintenance for 1301D
   / Oil and fluids - maintenance for 1301D #1
Adri122
Granada Hills, CA
Yanmar 1301d
Hello all. I'm new here :)
I have a 1301D and the gentleman I purchased it from no longer sells or maintains tractors.
It's due for an oil change but I'm not sure what kind of motor oil I should get or how much it needs.
Also not sure about the other fluids/items I should be checking out. Any advice would be greatly appreciated!
Thanks
Adri
   / Oil and fluids - maintenance for 1301D #2
Thanks
Adri
Welcome:thumbsup:.. Use any diesel rated oil. Don't know how much your mod will take.. Hyd fluid should meet JD 303 specs
   / Oil and fluids - maintenance for 1301D #3
Fluid & Oil Types I would put in about 3 quarts and start checking the dipstick. Once you get it in filter and correct level you will know next time what the capacity is.
If you go for a transmission fluid change be sure and pull and clean the metal strainer located behind a triangular flange low on the transmission. I don't know just where it is on the 1301. Maybe somebody out there knows and will respond.
Thanks for the tips!
2018 New Holland T8.350 MFWD Tractor (A53342)
2018 New Holland...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2014 Chevrolet Tahoe (A52377)
2014 Chevrolet...
2013 Yamaha YDREx4 Electric Golf Cart (A51691)
2013 Yamaha YDREx4...
