diesel fuel additive??????????
   / diesel fuel additive?????????? #11
It takes a lot of practice to become an expert "glugger". I got mine during the old Miller Hi Life days. /forums/images/graemlins/grin.gif
   / diesel fuel additive?????????? #12
(This is the white bottle)
Diesel Kleen® +Cetane Boost® is the premier “performance” product on the market. Diesel Kleen is loaded with cetane, detergency and lubricity additives to keep your diesel engine running at peak performance.
· Ultra Low Sulfur Diesel (ULSD) Compliant — does not affect the sulfur content ofdiesel fuel · Reduces visible exhaust emissions (HC, PM) up to 50 percent and reduces NOx and CO emissions up to 28 percent · Boosts cetane up to 6 numbers — engines run smoother with less power lag, reducedemissions and easier cold starts · Decreases fuel consumption up to 8 percent — fuel savings exceed cost of additive · Cleans dirty fuel injectors — exceeds Cummins L10 Injector Depositing TestSuperior specifications · Contains Slickdiesel® for maximum fuel lubrication — protects fuel injectors and pumps against accelerated wear from Low and Ultra Low Sulfur Diesel (ULSD) fuels · Reduces piston and combustion chamber deposits — reduces soot blow-by and engine oil thickening · Increases power — reduces need for downshifting during high-load conditions · Exceeds industry standards for thermal stability — improves diesel fuel’s resistance to thermal and oxidative degradation · Stabilizes stored fuel — protects against conditions that promote microbial growth · Effective in all diesel fuels, including Ultra Low Sulfur Diesel (ULSD) and biodiesel
(This is the grey bottle but looks like they changed it to a white bottle???)
This is the product of choice for optimal winter operation. Diesel Fuel Supplement® contains the most effective antigel additive package available in the diesel industry - no blending with No.1 diesel or kerosene is needed to achieve maximum winter protection. The cetane improver in Diesel Fuel Supplement provides up to 4 numbers of cetane boost for easier cold starts and a smoother running engine, while detergents clean fuel injectors to provide more power and less fuel consumption.
Winter Performance Benefits:
· Prevents fuel gelling in temperatures as low as -40°F. No Gelling Guaranteed!
· Equals the performance of a 50/50 blend of No. 2 and No. 1 diesel fuels
· Lowers Cold-Filter Plugging Point (CFPP) as much as 36°F. — keeps fuel-filters from plugging with wax
· Boosts cetane up to 4 numbers for easier cold starts
· Contains anti-icing additives — protects against fuel-filter icing
Year-Around Performance Benefits:
· Ultra Low Sulfur Diesel (ULSD) Compliant — does not affect the sulfur content of diesel fuel
· Effective in all diesel fuels, including ULSD and biodiesel blends containing up to 20% biodiesel (B20)
· Boosts cetane up to 4 numbers — engines run smoother with less power lag
and reduced emissions
· Cleans dirty fuel injectors — exceeds Cummins L10 Injector Depositing Test Superior specifications
· Reduces visible exhaust emissions (HC, PM) up to 25 percent and reduces NOx and CO emissions up to 14 percent
· Decreases fuel consumption up to 5 percent — fuel savings exceed cost of additive
· Stabilizes fuel in equipment tanks — improves diesel fuel’s resistance to thermal and oxidative degradation
· Stabilizes stored fuel — protects against conditions that promote microbial contamination
The white bottle has more cetane but lacks antigel additives and the grey has less cetane in it but has the antigel additives added /forums/images/graemlins/grin.gif
   / diesel fuel additive?????????? #13
You'd better read the bottle. I can tell you that side by side they were almost identical unlike the quotes above. If I read the above quotes right then I would rather have the white bottle.
   / diesel fuel additive?????????? #14
I made a mistake above. I have them reversed /forums/images/graemlins/tongue.gif
The white bottle (diesel fuel supplement+cetane boost) has the anti-gel additive.
The grey bottle (Diesel Kleen® +Cetane Boost) does not have anti-gel additives.
Also on their web site it looked like they made there grey bottle white???
   / diesel fuel additive?????????? #15
I even read the bottle on Saturday since I was so confused. The grey bottle had the bit about biological conditions but not antigel. It makes so much more sense now.
I burned 6 gallons of off-road on Saturday and now that I've started using the PS additive with the OR it seems to smoke less when under high loads. I was using my box blade as a poor mans chisel plow so I discovered that 5 ripper shanks buried deep takes lots of power but tills really well.
so guys being in mississippi where the temp usually doesn't get below 20 degrees f,should i even be concerned about gelling of the diesel fuel? or should i be more concerned about the almost 100 percent humidity in the summers?someone please help me with this,i am such a newbie to this diesel stuff?
thanks again fellas,
whitearrow->>>----------------->
   / diesel fuel additive?????????? #17
You probably don't have to worry about gelling from temperature, but diesel can grow algae in it. You should at least use a biocide treatment, or a multipurpose treatment that includes a biocide.
   / diesel fuel additive?????????? #18
Whitearrow just use the grey bottle (diesel kleen) and you will be just fine. Use it all year round and you will be good to go /forums/images/graemlins/wink.gif
   / diesel fuel additive?????????? #19
Links to the two PS products. You will find the MSDS sheets there too which it would not hurt you to review and maybe download for future reference.
Diesel Kleen
   / diesel fuel additive?????????? #20
I use "Sta-bil" in my gas equipment so saved an empty and refilled it with the "white bottle" Power Service. The sta-bil bottle has a graduated vial filled from the main side attached, making it very easy to measure my 3.5 oz, exactly
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2010 CATERPILLAR D6N LGP DOZER (A51406)
2010 CATERPILLAR...
RV Hitch (A50121)
RV Hitch (A50121)
2004 TerraGator 8104 (A55301)
2004 TerraGator...
UNUSED LANDHONOR LHR-MS0810 METAL SHED (A54757)
UNUSED LANDHONOR...
