(This is the white bottle)
Diesel Kleen® +Cetane Boost® is the premier “performance” product on the market. Diesel Kleen is loaded with cetane, detergency and lubricity additives to keep your diesel engine running at peak performance.
· Ultra Low Sulfur Diesel (ULSD) Compliant — does not affect the sulfur content ofdiesel fuel · Reduces visible exhaust emissions (HC, PM) up to 50 percent and reduces NOx and CO emissions up to 28 percent · Boosts cetane up to 6 numbers — engines run smoother with less power lag, reducedemissions and easier cold starts · Decreases fuel consumption up to 8 percent — fuel savings exceed cost of additive · Cleans dirty fuel injectors — exceeds Cummins L10 Injector Depositing TestSuperior specifications · Contains Slickdiesel® for maximum fuel lubrication — protects fuel injectors and pumps against accelerated wear from Low and Ultra Low Sulfur Diesel (ULSD) fuels · Reduces piston and combustion chamber deposits — reduces soot blow-by and engine oil thickening · Increases power — reduces need for downshifting during high-load conditions · Exceeds industry standards for thermal stability — improves diesel fuel’s resistance to thermal and oxidative degradation · Stabilizes stored fuel — protects against conditions that promote microbial growth · Effective in all diesel fuels, including Ultra Low Sulfur Diesel (ULSD) and biodiesel
(This is the grey bottle but looks like they changed it to a white bottle???)
This is the product of choice for optimal winter operation. Diesel Fuel Supplement® contains the most effective antigel additive package available in the diesel industry - no blending with No.1 diesel or kerosene is needed to achieve maximum winter protection. The cetane improver in Diesel Fuel Supplement provides up to 4 numbers of cetane boost for easier cold starts and a smoother running engine, while detergents clean fuel injectors to provide more power and less fuel consumption.
Winter Performance Benefits:
· Prevents fuel gelling in temperatures as low as -40°F. No Gelling Guaranteed!
· Equals the performance of a 50/50 blend of No. 2 and No. 1 diesel fuels
· Lowers Cold-Filter Plugging Point (CFPP) as much as 36°F. — keeps fuel-filters from plugging with wax
· Boosts cetane up to 4 numbers for easier cold starts
· Contains anti-icing additives — protects against fuel-filter icing
Year-Around Performance Benefits:
· Ultra Low Sulfur Diesel (ULSD) Compliant — does not affect the sulfur content of diesel fuel
· Effective in all diesel fuels, including ULSD and biodiesel blends containing up to 20% biodiesel (
B20)
· Boosts cetane up to 4 numbers — engines run smoother with less power lag
and reduced emissions
· Cleans dirty fuel injectors — exceeds Cummins L10 Injector Depositing Test Superior specifications
· Reduces visible exhaust emissions (HC, PM) up to 25 percent and reduces NOx and CO emissions up to 14 percent
· Decreases fuel consumption up to 5 percent — fuel savings exceed cost of additive
· Stabilizes fuel in equipment tanks — improves diesel fuel’s resistance to thermal and oxidative degradation
· Stabilizes stored fuel — protects against conditions that promote microbial contamination
The white bottle has more cetane but lacks antigel additives and the grey has less cetane in it but has the antigel additives added /forums/images/graemlins/grin.gif
