Hydraulic 3 point hitch Ford 5000
   / Hydraulic 3 point hitch Ford 5000 #1
Jejjones
Tuscaloosa
1973 Ford 5000
Working on a Ford 5000 project. Unable to get the hydraulics on the lift arms of the 3 poinh hitch working. I have replaced the piston seals the seals on the lift cover and he seals on the external hydrolics. The pump and the external hydrolics are working fine. I can lift the 3 point hitch by blowing compresed air into one of the lumens under the external valve controls. The external hydrolics also contenue working when the hydraulic valve is in either in or out position. any help with this issue would be greatly appreciated.
   / Hydraulic 3 point hitch Ford 5000 #2
did you clean the valves while you was working on the seals in the lift cylinder because there is two valves one is most likely stuck
I cleaned the valve that you pull to engage the external hyrolics. Have not worked on the valves in the cylinder.
   / Hydraulic 3 point hitch Ford 5000 #4
There's a good chance that your external remote is stuck and causing the open-center system to block flow to the 3PH. If you get that valve fixed, the 3PH may work. Does your tractor also have a loader?
No loader. Are you takling about the valve that operates the external hydraulics on top of the cover or the selector valve?
   / Hydraulic 3 point hitch Ford 5000 #6
I had a problem with my 72 ford 2000 with the lift arms .The Draft control leaver under the seat that lets the 3 point arms fall right down and float was rusted up under the cover in the valve. I removed those parts and it fixed it but it will not float anymore .
   / Hydraulic 3 point hitch Ford 5000 #7
I'm thinking the external hydraulic valve may be a remote that routes all fluid to the remote circuit when it is operated. However, re-reading your post, it seems to be working fine. Sorry for the false alarm.
   / Hydraulic 3 point hitch Ford 5000 #8
i would check the valves in the cylinder that is most likely your trouble
It was a valve stuck, working great thanks for the advice.
JOHN DEERE 54D LOT NUMBER 160 (A53084)
JOHN DEERE 54D LOT...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2021 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2021 Ford F-250 XL...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2021 Chevrolet Silverado 5500HD Service Truck, VIN # 1HTKHPVKXMH043579 (A51572)
2021 Chevrolet...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
