Better to idle the tractor or turn it off?
   / Better to idle the tractor or turn it off? #1
HatTrickHero11
California
Kubota L245
I live on about 3 acres and we had two huge mulch piles dumped. I take the bucket and get a scoop and haul it to the back yard to spread around the plants to prevent weeds. Now when I have to park the tractor and manually unload the stuff my hand so I can better spread it.(takes around 10 minutes) should I slow the RPMs and idle the tractor, or turn it off?
It's an older tractor. Maybe the later 80s
   / Better to idle the tractor or turn it off? #2
Conventional wisdom would say that if you're gonna be off of it for more than 2-3 minutes, shut it down.
However, fuel consumption at idle and no load on the engine is very minimal.
You will probably get opinions both ways.
   / Better to idle the tractor or turn it off? #3
let it run, less wear on starter.
   / Better to idle the tractor or turn it off? #4
Turn it off, less hours on the engine.
   / Better to idle the tractor or turn it off? #6
It takes us about 10 minutes per load when hauling manure. We would never think of letting the loader tractor idle needlessly for that long.
   / Better to idle the tractor or turn it off? #7
I would shut it off.... saves some fuel, less wear on the engine, & better for the environment. Maybe it does work the starter more to crank it up a few more times, but that's the tradeoff.
   / Better to idle the tractor or turn it off? #8
On the first load I would let it run just to get the engine warmed and such. On subsequent loads I would probably shut it off.........but not always.
Kinda depends on the mood I'm in.........sometimes the 'purr' of the diesel engine is a soothing sound.
And theres also the times when I don't want to hear the wife.......then I go to high idle:laughing::laughing:
   / Better to idle the tractor or turn it off? #9
Oh you better hope she don't find out you said that or your going to have a honey:laughing: do list a mile long
   / Better to idle the tractor or turn it off? #10
All the new John Deere and, I believe, Kubota manuals have warnings about extended idling for diesels because of carbon build-up.
Personally I go with the 3 or 4 minute rule... Longer than that I shut it off. I might also look for ways to shorten wait, like pulling off mulch in large quantities and going back later to actually spread it.
2006 CATERPILLAR 304C (A58214)
2006 CATERPILLAR...
40ft T/A Gooseneck Flatbed Equipment Trailer (A55851)
40ft T/A Gooseneck...
SKID STEER ATTACHMENT SIFT BUCKET (A58214)
SKID STEER...
Toyota 8BPU15 3,000 LB Stand-On Electric Forklift (A59228)
Toyota 8BPU15...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
20704 (A55853)
20704 (A55853)
