Better to idle the tractor or turn it off?
   / Better to idle the tractor or turn it off? #1
HatTrickHero11
California
Kubota L245
I live on about 3 acres and we had two huge mulch piles dumped. I take the bucket and get a scoop and haul it to the back yard to spread around the plants to prevent weeds. Now when I have to park the tractor and manually unload the stuff my hand so I can better spread it.(takes around 10 minutes) should I slow the RPMs and idle the tractor, or turn it off?
It's an older tractor. Maybe the later 80s
   / Better to idle the tractor or turn it off? #2
Conventional wisdom would say that if you're gonna be off of it for more than 2-3 minutes, shut it down.
However, fuel consumption at idle and no load on the engine is very minimal.
You will probably get opinions both ways.
   / Better to idle the tractor or turn it off? #3
let it run, less wear on starter.
   / Better to idle the tractor or turn it off? #4
Turn it off, less hours on the engine.
   / Better to idle the tractor or turn it off? #6
It takes us about 10 minutes per load when hauling manure. We would never think of letting the loader tractor idle needlessly for that long.
   / Better to idle the tractor or turn it off? #7
I would shut it off.... saves some fuel, less wear on the engine, & better for the environment. Maybe it does work the starter more to crank it up a few more times, but that's the tradeoff.
   / Better to idle the tractor or turn it off? #8
On the first load I would let it run just to get the engine warmed and such. On subsequent loads I would probably shut it off.........but not always.
Kinda depends on the mood I'm in.........sometimes the 'purr' of the diesel engine is a soothing sound.
And theres also the times when I don't want to hear the wife.......then I go to high idle:laughing::laughing:
   / Better to idle the tractor or turn it off? #9
Oh you better hope she don't find out you said that or your going to have a honey:laughing: do list a mile long
   / Better to idle the tractor or turn it off? #10
All the new John Deere and, I believe, Kubota manuals have warnings about extended idling for diesels because of carbon build-up.
Personally I go with the 3 or 4 minute rule... Longer than that I shut it off. I might also look for ways to shorten wait, like pulling off mulch in large quantities and going back later to actually spread it.
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2019 KENWORTH T680...
SKID STEER ATTACHMENT GRAPPLE GRUBBER (A58214)
SKID STEER...
2021 CATERPILLAR 308CR EXCAVATOR (A60429)
2021 CATERPILLAR...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
1453 (A57192)
1453 (A57192)
